jims914 |
Member ![]() ![]() Group: Members Posts: 140 Joined: 11-March 11 From: Tempe,AZ Member No.: 12,816 Region Association: Southwest Region ![]() ![]() |
Targa top makes noise at low speed 5-10 mph does not make a difference if windows are up or down ?
The seals are in good condition. Any suggestions ? |
bdstone914 |
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,125 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 ![]() |
Several things can cause that. Wrong top. Early and late tops have different width and height rubber block that fit into the rear latch tops. Worn rear latch hooks or worn compressed rear seal. Loose front latches.
Get out a quarter and a nickle. Place each one in between the bumps on the rear latch. If a quarter fits it is an early latch. A nickle will fit a laye latch. Then place the coins on the top of the rubber block to see if the top matches the latches. |
Cairo94507 |
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,441 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California ![]() ![]() |
Excellent tip Bruce. (IMG:style_emoticons/default/beerchug.gif)
jims914 |
Hello Bruce,
Thanks for the info, but I have had the car for 46 years it is still a 50K car ? The rear seal is good latches work great ? |
Lo-Fi Version | Time is now: 22nd September 2025 - 11:28 PM |
