| ctc911ctc |
Oct 19 2025, 06:03 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,266 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
1974, 2.0 all stock and original
Teeners I rebuilt the front end , bushings, hardware, brakes, everything powder coated and also stock bilstien inserts 2 years ago http://www.914world.com/bbs2/index.php?sho...7&hl=Powder On the right front when the suspension is unloaded, it clanks - loud I inspected for safety today and will take the suspension apart to inspect the insert asap Any guidance as to what it could be? Thank you teeners! |
| rjames |
Oct 19 2025, 06:12 PM
I'm made of metal ![]() ![]() ![]() ![]() Group: Members Posts: 4,402 Joined: 24-July 05 From: Shoreline, WA Member No.: 4,467 Region Association: Pacific Northwest
Check to see if the gland nut is tight. Torque spec is fairly high and if not tightened enough they can loosen up.
| ctc911ctc |
Oct 19 2025, 06:26 PM
Gland-nut? Well my mind went there, will figure out the suspension version of this phrase and get back to you (IMG:style_emoticons/default/biggrin.gif) Check to see if the gland nut is tight. Torque spec is fairly high and if not tightened enough they can loosen up. |
| L-Jet914 |
Oct 19 2025, 06:46 PM
Member ![]() ![]() Group: Members Posts: 365 Joined: 24-October 12 From: Davis, CA Member No.: 15,080 Region Association: Northern California |
The torque spec from Bilstein was 95ft lbs + or - 7ft lbs (little paper instruction insert that comes with the inserts) for the strut insert retaining nut. I had a clunk from the left front on my father's 914 before I replaced the strut inserts. Found the left front strut insert retaining nut was finger tight from the person who installed them in a repair shop many years ago before I started to go through my father's 914. I torqued the retaining nuts to spec with the Bilstein tool adapter when I put the new strut inserts in. No more clunk.
| ctc911ctc |
Oct 19 2025, 06:51 PM
The torque spec from Bilstein was 90ft lbs (little paper instruction insert that comes with the inserts) for the strut insert retaining nut. I had a clunk from the left front on my father's 914 before I replaced the strut inserts. Found the left front strut insert retaining nut was finger tight from the person who installed them in a repair shop many years ago before I started to go through my father's 914. I torqued the retaining nuts to spec with the Bilstein tool adapter when I put the new strut inserts in. No more clunk. Excellent, our next move - tool adapter? In some of the posts pipe wrenches were mentioned- not here, in a suspension forum (IMG:style_emoticons/default/smile.gif) |
| L-Jet914 |
Oct 19 2025, 09:52 PM
The torque spec from Bilstein was 90ft lbs (little paper instruction insert that comes with the inserts) for the strut insert retaining nut. I had a clunk from the left front on my father's 914 before I replaced the strut inserts. Found the left front strut insert retaining nut was finger tight from the person who installed them in a repair shop many years ago before I started to go through my father's 914. I torqued the retaining nuts to spec with the Bilstein tool adapter when I put the new strut inserts in. No more clunk. Excellent, our next move - tool adapter? In some of the posts pipe wrenches were mentioned- not here, in a suspension forum (IMG:style_emoticons/default/smile.gif) This is the gland nut tool for the bilstein strut insert retaining nut. I placed the order directly through Bilstein. I think it was just over $20 shipped to my door. Re-read the installation instructions and the recommended torque spec from Bilstein is 95 + or - 7ft lbs. ![]() |
| 914Sixer |
Oct 20 2025, 05:48 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,309 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Tool is $8+shipping a Sierra Madre Corp
| mepstein |
Oct 20 2025, 07:21 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,202 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A locking tool used for bicycle bottom brackets works well but pipe wrench will usually get the job done in a pinch.
| ctc911ctc |
Oct 20 2025, 09:34 AM
Don't tell anyone - I may use the pipe wrench method ...... (IMG:style_emoticons/default/evilgrin.gif)
| mepstein |
Oct 20 2025, 11:43 AM
Don't tell anyone - I may use the pipe wrench method ...... (IMG:style_emoticons/default/evilgrin.gif) Definitely the best way to remove. I’ve done dozens of them. Might gouge the gland nut a little while tightening but it’s all hidden under the strut dust cap. It’s more important to be tight than pretty. The stock “tool” is junk. |
| ctc911ctc |
Nov 4 2025, 12:51 AM
Used the pipe wrench method, car back together and no more clanking! Collar was 2 turns loose Thank you teeners Don't tell anyone - I may use the pipe wrench method ...... (IMG:style_emoticons/default/evilgrin.gif) Definitely the best way to remove. I’ve done dozens of them. Might gouge the gland nut a little while tightening but it’s all hidden under the strut dust cap. It’s more important to be tight than pretty. The stock “tool” is junk. |
Lo-Fi Version | Time is now: 4th November 2025 - 06:07 PM |
