| DennisV |
Oct 20 2025, 06:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,031 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
I assume something is meant to mount in the holes found on the rear trailing arm tabs. Can someone clarify or offer a picture?
It seems like a good place for a parking brake cable clamp, but I'm not seeing anything in the parts catalog or my photos from before disassembly. Thank you. The photo is from engine bay looking out toward passenger rear wheel. ![]() |
| fixer34 |
Oct 20 2025, 01:28 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,472 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
I assume something is meant to mount in the holes found on the rear trailing arm tabs. Can someone clarify or offer a picture? It seems like a good place for a parking brake cable clamp, but I'm not seeing anything in the parts catalog or my photos from before disassembly. Thank you. The photo is from engine bay looking out toward passenger rear wheel. ![]() I just went and looked at mine, the only bracket anywhere near that position is for the caliper parking brake cable and it looks quite different. Also, what is that shaft in the picture that appears to go to the trailing arm? |
| Cfletch |
Oct 20 2025, 02:59 PM
Member ![]() ![]() Group: Members Posts: 258 Joined: 30-January 14 From: Santa Barbara Member No.: 16,941 Region Association: Southern California |
I assume something is meant to mount in the holes found on the rear trailing arm tabs. Can someone clarify or offer a picture? It seems like a good place for a parking brake cable clamp, but I'm not seeing anything in the parts catalog or my photos from before disassembly. Thank you. The photo is from engine bay looking out toward passenger rear wheel. ![]() I just went and looked at mine, the only bracket anywhere near that position is for the caliper parking brake cable and it looks quite different. Also, what is that shaft in the picture that appears to go to the trailing arm? I am assuming you mean the e brake cable? That mounts into the hole on the trailing arm, or are you looking at the hard line going to the brake caliper? |
| Cairo94507 |
Oct 20 2025, 03:26 PM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,771 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
I could be wrong, but I do not recall seeing a bracket like that under my car. (IMG:style_emoticons/default/beerchug.gif)
| Cfletch |
Oct 20 2025, 03:43 PM
I could be wrong, but I do not recall seeing a bracket like that under my car. (IMG:style_emoticons/default/beerchug.gif) I agree with you, I do not have one on my passenger side, but do have something similar but with just 1 hole on my driver side arm. |
| trojanhorsepower |
Oct 20 2025, 04:02 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Ive been all up in my trailing arms lately and nothing like that on mine.
| brant |
Oct 20 2025, 04:57 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,278 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The six had one extra bracket to hold an oil line
Don’t think that is it That looks home made. From previous owner I assume |
| mepstein |
Oct 20 2025, 05:51 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,924 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
| DennisV |
Oct 20 2025, 06:27 PM
I just went and looked at mine, the only bracket anywhere near that position is for the caliper parking brake cable and it looks quite different. Also, what is that shaft in the picture that appears to go to the trailing arm? Thanks for taking a look. The "shaft" is the hard brake line to the caliper. I have something similar on the drivers side. This is a 1970 914-6 if it matters. ![]() |
| Montreal914 |
Oct 20 2025, 11:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,205 Joined: 8-August 10 From: Claremont, CA Member No.: 12,023 Region Association: Southern California
Interesting... (IMG:style_emoticons/default/popcorn[1].gif)
| sixnotfour |
Oct 21 2025, 12:30 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,379 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
keeps e brake cable off of header.. wrong side ...oops
| Nana's_914 |
Jul 25 2026, 07:07 PM
Member ![]() ![]() Group: Members Posts: 123 Joined: 27-October 06 From: San Diego, CA Member No.: 7,100 Region Association: Southern California |
Found an underside photo of a 914-6 with the brake cable attached to that trailing arm tab. My '74 does not have the tabs on the trailing arms. Anyone have the tab dimensions to help replicate them? Length, width, hole location?
(IMG:http://www.914world.com/bbs2/uploads_offsite/goldenbarngarage.com-7100-1785020328.1.jpg) https://goldenbarngarage.com/wp-content/upl...15-1536x864.jpg |
| DennisV |
Aug 14 2026, 07:24 PM
Found an underside photo of a 914-6 with the brake cable attached to that trailing arm tab. My '74 does not have the tabs on the trailing arms. Anyone have the tab dimensions to help replicate them? Length, width, hole location? Sorry for the delay. Only got back to the car this week. The tab on the driver's side trailing arm on our car is roughly 20 mm wide x 35 mm tall. |
Lo-Fi Version | Time is now: 6th October 2026 - 05:00 AM |
