| kenshapiro2002 |
Nov 10 2025, 04:46 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 23-July 09 From: Bawlmer, MD Member No.: 10,598 Region Association: MidAtlantic Region |
It’s fine with adjusting up and down. It’s seriously loose with the in and out. At any speed it just folds in. Trying to figure out if it’s the nut behind the glass or at the base of the stem itself. Then… how to get to it! TIA
| 914Sixer |
Nov 10 2025, 05:55 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,315 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Take mirror off and turn it over, 10mm nut should be visible. Tighten up and reinstall.
| kenshapiro2002 |
Nov 10 2025, 06:16 PM
| Spoke |
Nov 10 2025, 06:17 PM
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,270 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None
| infraredcalvin |
Nov 10 2025, 09:15 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,699 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
IIRC that nut needs a very narrow deep socket… i also remember it having a spring that compresses to tighten it up…
| GaroldShaffer |
Nov 10 2025, 10:11 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,639 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
| brant |
Nov 11 2025, 10:13 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,094 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
The one you want to tighten is under the glass
So you have to remove the glass from the mirror It is held in the mirror with a thin plastic seal. It’s tricky to pull the seal out. A bit of prying without breaking the glass or bending of the lip on the metal that holds it together |
| mepstein |
Nov 11 2025, 12:55 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,224 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
The one you want to tighten is under the glass So you have to remove the glass from the mirror It is held in the mirror with a thin plastic seal. It’s tricky to pull the seal out. A bit of prying without breaking the glass or bending of the lip on the metal that holds it together Use your fingernail or a plastic lever. Do not use a screwdriver. |
| chmillman |
Nov 11 2025, 01:14 PM
Member ![]() ![]() Group: Members Posts: 210 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Also depends on whether you have an original or an aftermarket. My RH mirror is aftermarket and the body is chrome plastic. I also needed to tighten the nut underneath. If it’s “folding in” that’s what you need to tighten. I actually turned down a 10mm socket to fit, the space was really tight.
| mepstein |
Nov 11 2025, 02:06 PM
Also depends on whether you have an original or an aftermarket. My RH mirror is aftermarket and the body is chrome plastic. I also needed to tighten the nut underneath. If it’s “folding in” that’s what you need to tighten. I actually turned down a 10mm socket to fit, the space was really tight. I also ground down a cheap 10mm to use as a “mirror” socket. |
Lo-Fi Version | Time is now: 12th November 2025 - 01:06 AM |
