| dlindzey |
Nov 18 2025, 03:44 PM
repeat offender ![]() ![]() Group: Members Posts: 51 Joined: 8-April 14 From: texas Member No.: 17,226 Region Association: Southwest Region |
I am changing oil and got stuck at the oil strainer. The outer piece has come off and i have removed the paper washer that was under it. It was not easy to pull the outer piece off.
I removed what I will call an odd nut that connects to a stud that is now sticking out of the retained portion of the oil strainer. The strainer appears to be aluminum. I can not dislodge this inner piece to get to the strainer and to complete the job as intented. Is this a common issue? Any solution/ Naturally not forcing the issue. |
| Shivers |
Nov 18 2025, 05:58 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,192 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| fiacra |
Nov 18 2025, 06:16 PM
Person.Woman.Man.Camera.TV ![]() ![]() ![]() Group: Members Posts: 643 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
A picture would be helpful. It could just be me but that description is confusing
| dlindzey |
Nov 18 2025, 07:15 PM
| dlindzey |
| dlindzey |
| dlindzey |
| dlindzey |
| Shivers |
Nov 18 2025, 07:32 PM
Is it number 12? (IMG:style_emoticons/default/lol-2.gif)
| Shivers |
Nov 18 2025, 07:39 PM
It is a replaceable part, about 20 bucks. Maybe someone put a sealer between the case and the flange on the strainer.
| bkrantz |
Nov 18 2025, 07:48 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,531 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
If you try prying out the strainer, be careful not to gouge or scratch the seating surface in the recess in the engine case.
| Superhawk996 |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,522 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
The other thing that happens is they get hung up on the stud threads. Cheap strainers aren’t made well and often have crappy fit at the studs with sharp edges getting deformed into the threads. Sometimes useful to spin it as if you are unthreading the strainer - even though it’s not threaded.
| dtmehall |
Nov 18 2025, 07:54 PM
Member ![]() ![]() Group: Members Posts: 208 Joined: 21-December 23 From: Farmington Hills, Michigan Member No.: 27,808 Region Association: Upper MidWest |
as noted above, there is a danger in prying with scratching the sealing surfaces.
you can use a screwdriver, but be careful where you put the fulcrum point you can also use a SMALL blade tool to get between the opening in the strainer and pull straight down good luck! |
| fiacra |
Nov 18 2025, 10:01 PM
Yeah, been there as well. There's nothing secret holding it on, the flange and and gasket are just stuck to the case. Just take your time and work it free. As already noted, if you damage it a replacement won't break the bank. It has been a while since I had a strainer get really stuck, but I believe I used a gasket scraper to get it free.
Lo-Fi Version | Time is now: 19th November 2025 - 01:02 AM |
