| tomeric914 |
Nov 23 2025, 07:58 PM
One Lap of America in a 914! ![]() ![]() ![]() Group: Members Posts: 1,319 Joined: 25-May 08 From: Syracuse, NY Member No.: 9,101 Region Association: North East States
Been kicking around the idea of using a hydraulic release bearing (HRB) instead of a slave cylinder, stock fork and stock release bearing. You could argue that this route is more expensive, but it isn't that much more than a stock throwout bearing. Most modern stickshifts use a HRB. They're simpler, cut out a bunch of moving parts and generally give better feel.
Goal is for the adapter to bolt in with no modifications to the trans or bellhousing other than to remove the two 6mm studs that hold on the throwout bearing guide tube. One fitting runs through one of the two inspection holes at the top for a bleeder fitting. The other will be a stainless braided line out the fork hole with a little bracket to hold it in place. You'll also need to install a clutch master cylinder of your choosing up front. If this interests you, I'll probably make a bunch of adapters and offer them up here. Let me know what you think. Could also be in kit form with everything needed. For now, here's a teaser shot of the mock-up. |
| sixnotfour |
Nov 24 2025, 08:25 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,147 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
Is that a GT3 Cup release bearing ?? OOPS... Tilton
| rfinegan |
Nov 25 2025, 07:15 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,189 Joined: 8-February 13 From: NC Member No.: 15,499 Region Association: MidAtlantic Region
looks like a GREAT solution ...follow this one for sure
| tomeric914 |
Nov 25 2025, 10:42 AM
Is that a GT3 Cup release bearing ?? OOPS... Tilton Yep, Tilton. They make the lowest profile HRB that fits. I started another thread asking if anyone else had their engine out to see what other's depth to the clutch fingers from the engine case were. My concern is that I am only looking at my setup. If someone else is interested, they will need to verify their clutch setup depth. |
| Ninja |
Nov 25 2025, 01:01 PM
Member ![]() ![]() Group: Members Posts: 173 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
I fought that fight 10 years ago on a big block cobra replica posted on my website.
https://granburyautoac.com/big-block-cobra-...ets-new-clutch/ Not my writing on the website... What that doesn't show is the fact that I had to remove and install the transmission 4 times before I got the "stack height" correct... The published specs for the slave cylinder were ONLY a general guide. It didn't work like it was supposed to. It required shimming the transmission back from the engine (fabrication type mod) before I both had enough free-play and the pressure plate fingers were not over-articulated. At that point it ALSO required modifying the transmission tunnel for shifter clearance... Clutch Master cylinder diameter and stroke were EXTREMELY important. It required a master change as well. A job that should have taken 4 hours took 20! (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) (IMG:style_emoticons/default/headbang.gif) This was on an engine/trans combo that was "normal" for the hot-rod crowd AND came with an earlier version of the part already installed which turned out to be the main reason for the previously failed clutch. The first shop botched the initial installation when the car was built. Both new and old was Tilton. The new slave had multiple "length adjustment" rings which HELPED! I love the IDEA of internal slave, when they are designed properly, they work fine. Never again will I try to use an internal retrofit slave kit IF usable external versions are available and I have room for them! Maybe the new stuff (10 years have passed) is better... Good luck! I will be watching your progress. (IMG:style_emoticons/default/ninja.gif) |
| Cupomeat |
Nov 27 2025, 07:19 AM
missing my NY 914 in VA ![]() ![]() ![]() Group: Members Posts: 1,345 Joined: 26-November 07 From: Oakton VA Member No.: 8,376 Region Association: MidAtlantic Region |
I'm interested in this solution. Sorry, I don't have access to get you dimensions.
Good luck! Eric |
| tomeric914 |
Nov 27 2025, 09:51 AM
I should have 5 of the adapters complete in the next couple of weeks.
If anyone is really interested and has their engine out. Please take a couple of dimensions as outlined in the link below and let me know so I can make sure this will work in your application. http://www.914world.com/bbs2/index.php?s=&...t&p=3233422 |
| tomeric914 |
Dec 10 2025, 08:15 AM
Prototype adapter installed and stack height verified!
It's interesting, different install manuals suggest the stack height anywhere from .100" to .250". This HRB in particular calls out .100" to .150" on a new clutch which seems just a bit too little in my opinion. I'll get some trans/engine spacers cut for .050" Next up is designing a bracket to hold the clutch and bleed lines. Not sure if I want to run hard lines or stainless braided with a protective sheath (IMG:style_emoticons/default/idea.gif) |
| sixnotfour |
Dec 10 2025, 09:29 AM
| tomeric914 |
Dec 26 2025, 10:37 AM
Thanks to @tygaboy for his mentions of SendCutSend, getting small sheet metal parts made is just too easy.
Start with modeling the part, in this case, the HRB bleeder and line bracket: Then order, receive and install said bracket: Hydraulic lines are next... |
| tygaboy |
Dec 27 2025, 09:50 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,774 Joined: 6-October 15 From: Petaluma, CA Member No.: 19,241 Region Association: Northern California
Yep, SendCutSend really is a game-changer for us home fabricators. Great looking bracket, btw. Lovely stuff!
| Cupomeat |
Dec 28 2025, 02:07 PM
| tomeric914 |
Jan 4 2026, 09:32 PM
More progress today. The fancy line bracket that I designed didn't quite work out as well as I thought so I went for a simpler approach although millimeters mattered to get the fittings in the right spot.
That makes it easier to access and route the line back to the clutch master cylinder. It also makes for safer routing of the lines inside the bellhousing to the HRB. I know what you're thinking. Yes, the bleed line makes a loop up high that could possibly trap air. Reality is that there would be a loop at the top no matter what. When bleeding, I need to make sure the bleeder bottle is held up high to keep from draining that column of fluid. My other OCD concern is "which fitting connection inside the bellhousing is going to leak?" (IMG:style_emoticons/default/barf.gif) Transmission is back in and everything looks clear inside the bellhousing. I did design a .060" spacer for the engine and transmission which gives the recommended clearance for clutch operation and wear over time. |
| sixnotfour |
Jan 5 2026, 05:48 AM
Why not use the adjustable pedal stop ?? no shim ? For wear..
| sixnotfour |
Jan 5 2026, 05:52 AM
| rfinegan |
Jan 5 2026, 09:40 AM
wow, looking good...keep the updates coming
| tomeric914 |
Jan 5 2026, 09:25 PM
Why not use the adjustable pedal stop ?? no shim ? For wear.. When the clutch disc wears and gets thinner, the clutch fingers extend, decreasing the gap between the throwout bearing and fingers. I was probably ok with the .110" gap, but Tilton wanted it to be .150". With the .063" spacer I'll be a bit higher than that. |
| Cupomeat |
Jan 9 2026, 06:02 PM
More progress today. The fancy line bracket that I designed didn't quite work out as well as I thought so I went for a simpler approach although millimeters mattered to get the fittings in the right spot. That makes it easier to access and route the line back to the clutch master cylinder. It also makes for safer routing of the lines inside the bellhousing to the HRB. I know what you're thinking. Yes, the bleed line makes a loop up high that could possibly trap air. Reality is that there would be a loop at the top no matter what. When bleeding, I need to make sure the bleeder bottle is held up high to keep from draining that column of fluid. My other OCD concern is "which fitting connection inside the bellhousing is going to leak?" (IMG:style_emoticons/default/barf.gif) Transmission is back in and everything looks clear inside the bellhousing. I did design a .060" spacer for the engine and transmission which gives the recommended clearance for clutch operation and wear over time. (IMG:style_emoticons/default/beerchug.gif) Looks great! |
Lo-Fi Version | Time is now: 2nd March 2026 - 11:44 PM |
