> What is the best adhesive to secure cork gaskets to the valve covers?
Geezer914
post Nov 26 2025, 05:34 PM
Geezer914
Looking for the best adhesive to glue the cork gaskets to the valve covers? What is everyone using? Thanks.
rjames
post Nov 26 2025, 05:40 PM
I'm made of metal
I go the opposite route. I just make sure the surface is clean and the gasket is where it should be. I've never had leaks and I've been using the same gaskets for a while now, too.
brant
post Nov 26 2025, 06:09 PM
I don’t like to use glue either
And haven’t tried see it for 40 years
If you must use glue
Gasket-Cinch would be the best product
Ninja
post Nov 26 2025, 06:17 PM
I use 3M yellow trim adhesive (Gorilla snot) between the VC and gasket and Smurf grease (Sta-lube marine) between the gasket and head. I'll reuse a cork gasket multiple times this way.
The Gorilla snot is a PIA to clean up/remove if you have to do it again.
This is overkill for most, but I've seldom had issues with leaks this way.
The type 4 VCG are pretty good by themselves. Wait till you have a cork gasket on an American straight 6 with few hold down bolts; that is when the Gorilla snot shines...
The new-fangled aluminum cored silicone gaskets solved lots of issues IMO.
I haven't seen that type of gasket for VW air-cooled stuff yet.
Root_Werks
post Nov 26 2025, 06:45 PM
Village Idiot
QUOTE(rjames @ Nov 26 2025, 03:40 PM) *
Shouldn't need anything with cork. If the gaskets don't fit, probably not a decent brand.
IronHillRestorations
post Nov 26 2025, 06:46 PM
I. I. R. C.
Be sure to inspect the valve covers and the sealing surface for flatness, gouges, dings, or pitting; all that could cause leaks. I’ve had to resort to adhesive and/or RTV for last resort for leakers, but I don’t like to do it. If you use RTV you don’t want to over do it and get it inside the engine.
I’ve also added extra gaskets tabs to hold the gasket in place.
914Rubber sells gaskets that are just a little thicker, which are nice.
JamesM
post Nov 26 2025, 07:32 PM
QUOTE(brant @ Nov 26 2025, 05:09 PM) *
(IMG:style_emoticons/default/agree.gif) That^
Also define "best", I mean you could technically epoxy your valve covers on for the best seal, you would just never be adjusting your valves again.
Problems I have with a lot of the silicone based RTV/whatever sealants people tend to throw on there are 1. It works fine until it doesn't and when the seal breaks its worse than not having used anything in the first place. 2. cleanup and reapplication is a nightmare.
Gasgacinch (and I usually only put it on the valve cover side) or nothing.
bkrantz
post Nov 26 2025, 08:33 PM
A million years ago I used 3M green "elephant snot" adhesive. So far my 21st century 914 experience uses no glue.
emerygt350
post Nov 26 2025, 08:38 PM
I think getting the gasket to sit still while you put the valve cover on is the problem for me with leaks. I use that red stuff as a glue, not a sealant. On my car I find the thick cork leaks, the cheap renz works better. I also suspect with the steel valve covers each car is going to behave a little differently.
FlacaProductions
post Nov 26 2025, 09:19 PM
The extra thick cork from 914rubber are fine but they were actually too thick for me.
Standard Victor Reinz with Gaskacinch between the gasket and the valve cover only.
https://a.co/d/4g9wN7m
2 User(s) are reading this topic (1 Guests and 0 Anonymous Users)
1 Members: Franz_x
- Lo-Fi Version Time is now: 27th November 2025 - 07:38 AM
