| DennisV |
Nov 27 2025, 09:31 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 833 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Has anyone had success repairing / replacing a broken stud in the front bumper top molding? One of the studs snapped off during disassembly, despite several soakings in Sea Foam. Best I can tell these are molded into the rubber. I can't think of a way to remove the remaining stud without making things worse. I could of course melt it out, but then I have no way to set a new stud. (IMG:style_emoticons/default/unsure.gif)
![]() I realize new ones are available for sale. This one is in quite good shape with the exception of that stud. Seems a shame to trash it. Especially when the new ones are hundreds of dollars. |
| IronHillRestorations |
Nov 27 2025, 09:52 AM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,905 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
You might try drilling it out and tapping it, then epoxy a stud. I’ve seen sheet metal screws used as well.
| DennisV |
Nov 27 2025, 10:08 AM
You might try drilling it out and tapping it, then epoxy a stud. I’ve seen sheet metal screws used as well. I didn't realize you could tap rubber. Is there an epoxy you've had good luck with? Most of my attempts to bond plastics with any amount of stress applied seem to fail. I see JB Weld has SuperWeld Extreme that claims it will work on rubber. |
| FlacaProductions |
Nov 27 2025, 10:40 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,124 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
I successfully used JB Weld years ago to place a stud that had pulled out of a rear lower spoiler on a 944 Turbo - very similar material to the 914 bumper tops. I'd try drilling it out, fill the hole with JB and then insert a new stud and let it set up. Just have to pay attention to make sure you have correct alignment and depth.
| Artfrombama |
Nov 27 2025, 10:54 AM
Artfrombama ![]() ![]() Group: Members Posts: 416 Joined: 21-January 24 From: North Alabama Member No.: 27,870 Region Association: South East States
I suggest bonding the rubber to the bumper with panel bond. May require roughing up the chrome under the rubber a bit...
| Garland |
Nov 27 2025, 12:30 PM
Restoration Fanatic ![]() ![]() ![]() Group: Members Posts: 1,425 Joined: 8-January 04 From: ......Michigan...... Member No.: 1,535 Region Association: Upper MidWest
I successfully used JB Weld years ago to place a stud that had pulled out of a rear lower spoiler on a 944 Turbo - very similar material to the 914 bumper tops. I'd try drilling it out, fill the hole with JB and then insert a new stud and let it set up. Just have to pay attention to make sure you have correct alignment and depth. (IMG:style_emoticons/default/agree.gif) Exactly! J&B |
| 914Sixer |
Nov 27 2025, 12:58 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,387 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Stud was in a metal washer. Can be drilled and tapped, JB optional if needed.
| 914rrr |
Dec 17 2025, 05:26 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,010 Joined: 1-July 03 From: Knoxville, TN Member No.: 874 Region Association: South East States |
It's been several years, but IIRC, I was able to weld a washer to a suitable bolt and weld it to the internal steel of the bumper top IF the internal steel of the bumper top is solid enough to be welded to.
| rgalla9146 |
Dec 17 2025, 08:24 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,904 Joined: 23-November 05 From: Paramus NJ Member No.: 5,176 Region Association: None
It's been several years, but IIRC, I was able to weld a washer to a suitable bolt and weld it to the internal steel of the bumper top IF the internal steel of the bumper top is solid enough to be welded to. (IMG:style_emoticons/default/agree.gif) Along the same line carefully use a small diameter hole saw to remove rubber around the remaining part of the stud. Mig a new 6mm stud to hopefully clean metal. Add support with JB weld. |
| DennisV |
Jan 11 2026, 09:02 PM
I successfully used JB Weld years ago to place a stud that had pulled out of a rear lower spoiler on a 944 Turbo - very similar material to the 914 bumper tops. I'd try drilling it out, fill the hole with JB and then insert a new stud and let it set up. Just have to pay attention to make sure you have correct alignment and depth. Thanks for this suggestion. I did basically what you said. * Dremel to level and make pilot hole * Drilled * Tapped * Used my new favorite product JB Weld Plastic Bonder to secure an M6 bolt that I cut to length. Turned out great. |
Lo-Fi Version | Time is now: 12th January 2026 - 02:24 AM |
