| DennisV |
Dec 3 2025, 07:26 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 955 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Working on 1970 914-6. Trying to verify what the correct plugs are for the various holes found in the frunk / underside.
I think I found most of my answers in What do you have under your front trunk? and 1974 914 Front Trunk Originality Question, Grommets/Drain Tube(s) threads. * Green rear of frunk (top of photo) - drain tubes that are listed in parts catalog as being for pop-up headlights. (914-502-429-10) * Blue in middle - Not shown in parts catalog. Use same plug as found on 914-6 hot air socket? (999-703-013-50) The exception I see is the 2 frontmost holes (bottom of photo). The listing I see in PDF parts catalog indicates that 914-559-253-10 buffer is for 72-. What goes there, if anything, for a 1970 car? Thank you. ![]() |
| sixnotfour |
Dec 3 2025, 08:34 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,260 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
rubber bumper for front valance.
when Porsche created PET,,, well some history was lost.. Attached image(s)
| sixnotfour |
Dec 3 2025, 09:27 PM
| DennisV |
May 31 2026, 07:35 PM
I installed that water drain tube in the recommended location. It hangs surprisingly low. Like not far from the road. Is this correct?
Lo-Fi Version | Time is now: 31st May 2026 - 10:33 PM |
