| chmillman |
Dec 16 2025, 04:20 PM
Member ![]() ![]() Group: Members Posts: 278 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
I took out my heater blower for access to the area underneath it, and while it is out I thought to replace these rather old, yellowed and slightly corroded connnectors.
The couplings came off the motor easily enough, but I was not able to easily remove the wires from the couplings - I had originally thought they were just another spade connector that should come off with a little coaxing, but they look somewhat different... Is there something special about these guys, were they not designed to be removed? |
| JeffBowlsby |
Dec 16 2025, 05:34 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,140 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
Those are two, of what I call 'long blade' male, 6mm, terminals, that mate with two female 6mm terminals. They mate in a double box housing and all terminals are removable by releasing the tang.
I dont recall if the terminals on the chassis harness (in your photo) are male or female, inspection should clarify. They are opposite gender from the mating terminals on the fan. |
| trojanhorsepower |
Dec 16 2025, 05:48 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,011 Joined: 21-September 03 From: Marion, NC Member No.: 1,179 Region Association: None |
Here are what mine look like with out the plastic bits.
| chmillman |
Dec 17 2025, 06:28 AM
OK, thanks guys -
What's also interesting is that I have this extra piece between the fan and the cable harness. I'm assuming it is the "suppressor" (RF noise) for "vehicles equipped with a radio" talked about in the install instructions...? ![]() The instructions say to be careful to respect the polarity - I assume that the motor is a simple DC brush motor whose speed is varied by the input voltage and reversing the polarity would make the fan run backwards... Did I get that right? |
Lo-Fi Version | Time is now: 17th December 2025 - 09:38 AM |
