| Petepat |
Dec 24 2025, 10:01 AM
Member ![]() ![]() Group: Members Posts: 70 Joined: 1-December 19 From: Florida Member No.: 23,691 Region Association: None |
Hi, a simple question (maybe!), can you remove/replace the pushrods on a 1.7L engine without having to take the engine out?
| 930cabman |
Dec 24 2025, 10:07 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,389 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
| Jack Standz |
Dec 24 2025, 06:45 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 635 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
Yes. But in some cases you will likely need to remove some pushrod tubes because the pushrod may not clear the chasis (depending on the type of pushrods, like steel versus stock aluminum, etc.).
| Superhawk996 |
Dec 24 2025, 07:56 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,596 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
IMHO the question isn’t can you . . . But should you.
The 914 as is the case with almost all mid-engine vehicles is not designed to have major work done with the engine in the vehicle. Removing push rods is major work. |
Lo-Fi Version | Time is now: 24th December 2025 - 10:54 PM |
