| FlacaProductions |
Dec 29 2025, 10:30 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,114 Joined: 24-November 17 From: LA Member No.: 21,628 Region Association: Southern California
Let’s talk about summer performance tires. And more likely - alternatives...
I'm in the market as my tires have aged out. (Sailun Atrezzo's - never seen 'em before - came with the car from the PO.) The low temperature thresholds of summer tires seemingly rule out summer performance models for me since my 914 does not USUALLY see the street during cold weather but it's not unheard of to go for a mid-winter ride in below-freezing temps if the sun is out and the roads are clean and dry. It does get stored in a garage that may go down to the mid-to-upper 30s. So what are some higher-performance suggestions for tires that can run year-round in 195/55/15s? It's what I currently have, the look that I like and what my speedo is calibrated to. Thanks! Brian |
| Cairo94507 |
Dec 29 2025, 11:03 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,534 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Hi Brian - I check for tires by going to Tire Rack's web site. I run 195x65x15 on my car. Cheers, Michael (IMG:style_emoticons/default/beerchug.gif)
https://www.tirerack.com/tires/TireSearchRe...performance=ALL |
| chmillman |
Dec 29 2025, 11:13 AM
Member ![]() ![]() Group: Members Posts: 303 Joined: 15-June 24 From: Switzerland Member No.: 28,183 Region Association: Europe
Running 195/65 15’s also on my 7x15 Fuchs. Michelin Primacy 4’s. Come out close to or at the top in many reviews of dry or wet adherence. IMO decent compromise performance/price/economy. YMMV - literally.
| Jamie |
Dec 29 2025, 12:30 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,176 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Let’s talk about summer performance tires. And more likely - alternatives... I'm in the market as my tires have aged out. (Sailun Atrezzo's - never seen 'em before - came with the car from the PO.) The low temperature thresholds of summer tires seemingly rule out summer performance models for me since my 914 does not USUALLY see the street during cold weather but it's not unheard of to go for a mid-winter ride in below-freezing temps if the sun is out and the roads are clean and dry. It does get stored in a garage that may go down to the mid-to-upper 30s. So what are some higher-performance suggestions for tires that can run year-round in 195/55/15s? It's what I currently have, the look that I like and what my speedo is calibrated to. Thanks! Brian I have been running 205x65x15" on original steel 5.5"x15" rims, on my 3rd set during ownership of 24 yrs. Currently using Vredenstein HiTrac A/S from Tire Rack which replaced Michelin Pilot A/S which are apparently NLA. Do have a 12mm spacer in front, none needed in rear. |
| Ninja |
Dec 29 2025, 01:02 PM
Member ![]() ![]() Group: Members Posts: 59 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
In that size Tire Rack has three I'd consider
The Hankook V2 The Falken The Toyo I'd lean towards the Toyo first, Hankook second, Falken third. All closely priced. |
| infraredcalvin |
Dec 29 2025, 01:40 PM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,705 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
But would put the hankook first, Toyo’ 2nd (my personal preference) |
| Geezer914 |
Dec 29 2025, 04:45 PM
Geezer914 ![]() ![]() ![]() ![]() Group: Members Posts: 2,168 Joined: 18-March 09 From: Salem, NJ Member No.: 10,179 Region Association: North East States
If you run summer tires the temp should not go below 50°>. I had a set of Goodrich summer tires had sidewall cracks after one season. I live in NJ and the winter temps ruined the tires just sitting in the garage! If you get summer tires, remove them if temps are going below 50° and store them in a warm place over the winter.
Lo-Fi Version | Time is now: 29th December 2025 - 06:37 PM |
