> Replacing original factory clutch
JeffBowlsby
post Dec 31 2025, 04:42 PM
Replacing an original factory clutch dated 7/73, as it had started shuddering at launch and making weird noises. A "while I was in there" job. ~50Kmi car. This transaxle had never been previously removed from the car.
See the original disk compared to the new replacement disk.
The orig clutch disk has some kind of rubber 'spring/cushion chunks ' inside, mostly deteriorated and most of the rubber chunks are missing now. A piece of a remaining chunk can be seen in the round hole viewport at the clutch disk center.
Original flywheel had been factory balanced and the bolts were not clearanced. No visible wear on flywheel bolt heads.
Clutch disk is made of two thinner friction disks separated by a center metal plate carrier plate with flat springs presumably to somewhat cushion the shift change process. I noticed that the friction disk on the pressure plate side had more wear (was thinner) than the friction disk on the flywheel side.
914Sixer
post Dec 31 2025, 05:13 PM
Original clutch was made by LUK. Still in business today.
Superhawk996
post Dec 31 2025, 05:27 PM
Sheesh - haven’t seen an original clutch myself since the 80s. (IMG:style_emoticons/default/aktion035.gif)
sixnotfour
post Dec 31 2025, 06:17 PM
68 912..just replaced same clutch dated /74
Ninja
post Dec 31 2025, 06:46 PM
Does anyone know when Porsche moved to the damper springs?
Those rubber dampers suck bigtime, especially when the rubber is 50 years old!
The un-even wear (more to the pp side) is normal on everything.
The inner plate between the friction sections is critical.
A "race" clutch will often have a solid flat plate. A street clutch will have a "bent" wavy plate.
Either style can have the damper assembly as well. Most competition clutches do not.
Most street clutches have both the obvious spring or rubber dampers and the wavy plate between the friction surfaces. You should be able to slightly squeeze the two friction surfaces together. This style of friction mounting seriously reduces clutch grabbiness and judder.
I believe this style of friction mounting is classified as a "marchel" plate but I may have the terminology wrong.
For streetcar applications it is a requirement in my book. Often times you can see the waviness in the plate between the friction surfaces.
Of note: most modern clutch discs have no damper section and are solid plates but the flywheel is "dual mass". Many enthusiasts replace the heavy dual mass flywheels with lighter solids and then suffer the results. Massive judder, grabbiness, and often loud rattling from the transmission at idle are the normal results.
Want smoothness?
Have both a spring damper and the marcel plate in your clutch disc if you are not using a dual mass flywheel.
I believe Porsche changed over to dual mass set ups around the time they went water cooled. My 99 Boxster has a DM flywheel.
I hated DM flywheels at first, but I've now seen so much BS changing DM to solids that I have changed my opinions regarding them.
When I convert to the LGX V6/Boxster 6 speed combo I will try to use the stock GM DM flywheel...
wonkipop
post Dec 31 2025, 08:08 PM
had one of those in mine.
pulled it out in 2020 when we recommissioned.
the rubber core just gave up when we got the car going again after its 16 year sleep.
if they don't wear out they eventually turn to muck. material lifespan.
if it was not dead when i parked it up it sure did die during the long coma. (IMG:style_emoticons/default/biggrin.gif)
doesn't surprise me there are still some lurking in low mileage cars.
mine was at 44,000 when it was replaced.
very curious items.
i think those clutches were even in turbos.
the rubber core was supposed to assist in preventing clutch shudder.
smoother take off.
but to tell you the truth i have noticed no difference really in replacing it with the spring clutch.
i boxed mine away as one of those original parts i removed.
for the sake of silly history. (IMG:style_emoticons/default/biggrin.gif) (IMG:style_emoticons/default/beerchug.gif)
if nothing else you get to replace the RMS.
always a good thing to do on a car of this age.
nothing lasts for ever even if you barely use the car.
interestingly when we pulled the trans to do the clutch we found a factory label on top of it that was still there. whatever writing was on it had faded to nothing. maybe you found a label on yours when you dropped the trans?
rgalla9146
post Dec 31 2025, 10:16 PM
If the clutch disc can not 'float' on the input shaft splines the result will be more wear
on one side of disc or the other.
It can also cause difficult shifting.
Clutch discs often have a manufacture date stamped into a rivet or into one of the
stamped steel parts of the disc or even stenciled on.
Look closely.
8 User(s) are reading this topic (7 Guests and 0 Anonymous Users)
1 Members: Superhawk996
- Lo-Fi Version Time is now: 1st January 2026 - 12:09 AM
