> Push Rod Tube Source, weeding out the Junk
Jgilliam914
post Jan 4 2026, 12:48 PM
The last few times I bought them they were through EMPI
very light gauge metal and I would consider junk. One even had a pin hole in them
Where is a good place to source quality one?
TIA
Craigers17
post Jan 4 2026, 01:35 PM
The Type IV store sells billet aluminum, but they aren’t compatible with stock push rods. You have to use their chromoly push rods.
Here: https://lnengineering.com/ln-engineering-bi...-pushrod-tubes/
mmichalik
post Jan 4 2026, 03:43 PM
MikeM
PMB has good push rod tubes as well: https://pmbperformance.com/products/stainle...-t3-transporter
bdstone914
post Jan 4 2026, 04:05 PM
bdstone914
I have replated originals for $60 a set what engine? There are early larger diameter or 1.8, 2.0 that are smaller
GregAmy
post Jan 4 2026, 06:07 PM
I'm running Chris' stainless tubes and chromoly push rods on both the street and racer, call him to see if he's got them in stock:
https://tangerineracing.com/shop/ols/produc...s-pushrod-tubes
porschetub
post Jan 4 2026, 07:23 PM
QUOTE(bdstone914 @ Jan 5 2026, 10:05 AM) *
Bruce certainly has that covered ,great product and OEM ,cheers.
Jack Standz
post Jan 5 2026, 06:16 AM
QUOTE(mmichalik @ Jan 5 2026, 04:43 AM) *
(IMG:style_emoticons/default/agree.gif) Unless you're building a stroker motor, these are good ones. Otherwise, get the longer ones.
jim_hoyland
post Jan 6 2026, 05:53 PM
Get that VIN ?
Can the tubes and pushrods be replaced with motor in the car ?
TRP
post Jan 6 2026, 06:24 PM
QUOTE(jim_hoyland @ Jan 6 2026, 03:53 PM) *
According to the google machine, Yes, you can replace pushrods and tubes on a Porsche 914 with the engine in the car, though it's tedious work requiring removal of valve covers, rockers, and heart exchangers (recommended), often needing some tubes to tilt or partially remove due to chassis clearance, and demanding careful reassembly with proper torque and seals to prevent major oil leaks. It's challenging but doable by working on one cylinder at a time, often with the engine raised or on tall jack stands.
I give you this:
http://www.914world.com/bbs2/lofiversion/i...php?t29951.html
This feels like a question we could ask that new fancy 914world AI Agent.
- Lo-Fi Version Time is now: 7th January 2026 - 12:43 AM
