> Speedo Brown Wire Termination, Where the heck does it belong
DennisV
post Jan 12 2026, 09:10 PM
I have a brown wire hanging under the dash and I don't know where it should connect. The free end has an odd terminal on it. The other end is connected to the top of the speedometer. There is a second brown wire connected to the same spot on the speedometer.
On my wiring diagram, the only brown listing I see for the speedo is From: GND_Gauge_Daisy_Chain, To: GND_INST_PANEL. This doesn't really help me.
Any ideas?
rgalla9146
post Jan 13 2026, 07:10 AM
The connector is added on, not original. Maybe for radio ?
There are many ground males on the back of the instruments and brown jumper
wires between. Make certain each gauge is grounded.
windforfun
post Jan 13 2026, 11:48 AM
That's part of the ground daisy chain I believe. It's for a radio. If everything else works you can remove it. BTDT. Notice the male conversion tab.
DennisV
post Jan 15 2026, 11:07 AM
QUOTE(windforfun @ Jan 13 2026, 09:48 AM) *
Sorry to belabor this...
Ground "daisy chain" means it runs from one component through another to get grounded. Rather than direct to a ground point?
On my electrical diagram, I only find one reference to GND_Gauge_Daisy_Chain and that is on the speedo. Does that suggest this wire should go to another gauge? The diagram says it goes to GND_INST_PANEL, which appears to be a single wire terminating 7 different sources. I have not been able to find this GND_INST_PANEL location.
- Lo-Fi Version Time is now: 17th March 2026 - 04:16 PM
