| Lars OLesen |
Jan 25 2026, 03:03 PM
Newbie ![]() Group: Members Posts: 4 Joined: 13-December 19 From: Denamrk Member No.: 23,738 Region Association: None |
Hello all you very wise guys.. I have a 914/4 1974 2,0 that I´m collecting parts for a 2,7 /6 conversion for. Which flywheel and clutch will be best, and easiest to fit my conversion? Regards all the way form Denmark.. Lars |
| Steve |
Jan 25 2026, 07:17 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,006 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
Hello all you very wise guys.. I have a 914/4 1974 2,0 that I´m collecting parts for a 2,7 /6 conversion for. Which flywheel and clutch will be best, and easiest to fit my conversion? Regards all the way form Denmark.. Lars Change the flywheel on the 2.7,to a 911 2.0 flywheel and use a standard 911T 2.0 disk and pressure plate. This is the same disk and pressure plate used on the 914-4 2.0. I ran this on my 2.7 over 20 years with no slippage or other issues. |
Lo-Fi Version | Time is now: 26th January 2026 - 06:56 AM |
