| Chris914n6 |
Feb 19 2026, 04:32 PM
Jackstands are my life. ![]() ![]() ![]() ![]() Group: Members Posts: 3,535 Joined: 14-March 03 From: Las Vegas, NV Member No.: 431 Region Association: Southwest Region |
Maybe I'm calling them the wrong thing but I can't seem to find factory repro or generic fit clips to hold the hard brake lines to sheetmetal (engine bay in particular).
| TRP |
Feb 19 2026, 05:19 PM
Member ![]() ![]() Group: Members Posts: 348 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Are you talking about the rectangular white ones that have a rod/shaft that pushes into the clip to hold it to the firewall/engine bay?
I need two of those as well. Not sure what they are called. |
| TRP |
Feb 19 2026, 05:55 PM
They kind of look like this:
| 914Sixer |
Feb 20 2026, 04:44 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,480 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
This what your talking about?
Attached thumbnail(s) |
| DennisV |
Feb 20 2026, 05:54 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 921 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Maybe I'm calling them the wrong thing but I can't seem to find factory repro or generic fit clips to hold the hard brake lines to sheetmetal (engine bay in particular). Are you able to find it in the PDF parts catalog to provide a part number or better illustrate where it lives? The only plastic clip I'm seeing related to hard brake lines is: Pipe Clip (914-1,8V/1,8 914-2,0) 999-507-235-40 If it's like the one Mark posted, and they really are NLA, I could model that and 3D print a handful in ABS. I would just need someone to loan me an original to take dimensions from. I did this one for the 914-6 fuel rail. Attached thumbnail(s) |
| JeffBowlsby |
Feb 20 2026, 09:23 PM
914 Wiring Harnesses & Beekeeper ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,249 Joined: 7-January 03 From: San Ramon CA Member No.: 104 Region Association: None
It would be FANTASTIC if you would make these available. Can you print them in nylon 6?
Referring to the double fuel line clips shown above. |
| sixaddict |
Feb 21 2026, 11:22 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,066 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
(IMG:style_emoticons/default/agree.gif) I would be in for some .
| 914Sixer |
Feb 21 2026, 12:01 PM
The maybe available at VW sites. Single ignition wire holder. Used one in picture from theSamba
| 914werke |
Feb 21 2026, 01:01 PM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,657 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
(IMG:style_emoticons/default/agree.gif) Those are available new (I have them listed on my site).
The dual fuel line clips Mark posted an example of, I've not found a replacement source for, although Ive been rat-holing good used ones for a while. |
| Chris914n6 |
Feb 23 2026, 09:19 PM
I can see the confusion (IMG:style_emoticons/default/smile.gif)
My car, 75. 6mm hole fyi (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1771903185.1.jpg) My other car, 71. metal tabs (IMG:http://www.914world.com/bbs2/uploads_offsite/live.staticflickr.com-431-1771903191.2.jpg) |
| DennisV |
Feb 24 2026, 08:12 AM
It would be FANTASTIC if you would make these available. Can you print them in nylon 6? Referring to the double fuel line clips shown above. I have only printed PLA and ABS, but my printer is capable of handling Nylon. I'd need someone to loan me an original to take measurements from so I can make a CAD model. |
| JeffBowlsby |
Feb 24 2026, 01:11 PM
@DennisV
The fuel line clip is 2-pieces, a body and a separate solid ~5mm dia. rod, both of Nylon. The rod inserts into the hole centered in the clip body, and I see subtle bumps inside the hollow tube extension of the hole on the back side of the clip to friction hold the rod in place, once the rod is fully inserted. The two parts are a close tolerance friction fit. The plunger seems to be a uniform OD, not tapered. The clip body holds two fuel lines in parallel. The clip in the photos is broken, but it should have symmetrical arms. If this cannot be replicated, can something functionally similar be developed and printed? Attached image(s)
| 914werke |
Feb 24 2026, 03:40 PM
Your brake line clip (clarified) Are late only 75-76. Amongst the changes to the chassis that we made, doing away with the bendable tabs & replacing them which holes for those clips
| DennisV |
May 13 2026, 05:08 PM
I thought I'd share some progress on a project @JeffBowlsby and I have been fiddling with. First prototype.
Lo-Fi Version | Time is now: 13th May 2026 - 05:54 PM |
