| Cvrguy |
Mar 8 2026, 02:36 PM
Newbie ![]() Group: Members Posts: 24 Joined: 18-September 25 From: Los Angeles Member No.: 28,995 Region Association: None |
The essential question is how the bushings function. Do they regulate suspension movement in shear or are they solely serving a cushioning function? If it is the latter, a high quality non-petroleum based grease should function well while also serving a corrosion resistant role as well. Thoughts?
| Ninja |
Mar 8 2026, 04:38 PM
Member ![]() ![]() Group: Members Posts: 202 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
The bushings twist!
They should stay locked to both the body mount and the shaft. They should be tightened/locked at normal ride height and the farther you deflect them the more resistance they add (adds to spring rate). Grease is a BAD idea. I've used dish soap or diesel as an assembly lubricant. The EXCEPTION to this is bushings NOT made out of rubber. Urethane/Delrin/nylon (normal "performance" bushings) require specific lubricants (usually some type of silicon grease). It is a real good idea to add grease zerks to the bushing housings as these bushings squeak like hell when they get dry. I've never installed a set that didn't squeak at some point. Edit: Phil @Superhawk996 suggests glycerin as another option. I've not used that before, but liquid glycerin is super slippery. Might be worth trying if you're struggling with the soap. |
| Arkady |
Mar 10 2026, 12:26 PM
Newbie ![]() Group: Members Posts: 31 Joined: 13-May 22 From: Home, PA Member No.: 26,545 Region Association: MidAtlantic Region |
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place.
Not sure if this is applicable here, though. |
| Cvrguy |
Mar 10 2026, 02:23 PM
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place. Not sure if this is applicable here, though. Given that the bushings need to be fixed in position, I am looking for a way to increase the "working time" between installation and when the soap dries out. Would glycerin take longer or slower to set up? I'm not confident that the measurements I took prior to removal will be correct once installed. If they are incorrect, I could end up with too high a "bushing" spring rate. I'm curious as to how the factory did it initially. |
| brant |
Mar 10 2026, 02:30 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,184 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place. Not sure if this is applicable here, though. Given that the bushings need to be fixed in position, I am looking for a way to increase the "working time" between installation and when the soap dries out. Would glycerin take longer or slower to set up? I'm not confident that the measurements I took prior to removal will be correct once installed. If they are incorrect, I could end up with too high a "bushing" spring rate. I'm curious as to how the factory did it initially. original factory bushings are vulcanized.. or melted into place. not a technique that can be recreated at home. both the ID and OD are melted to the metal parts and create a twist in the rubber as the car changes up and down. The original rubber flexes to a point. aftermarket bushings usually spin on the shaft example roller bearings, or even zerks to lubricate the moving part for plastic bushings. and one that does not move freely will add resistance or add to the total spring rate. |
| Ninja |
Mar 10 2026, 02:35 PM
The fastest of all of the lubricants I've used is the diesel.
I use that on BMW front A arm rear mount which is cylindrical and is pressed on to a 3/4" shaft. You have to slam the critters on, lock the body mount bolts, then drop the car and load the front suspension (couple of fat guys in the car does this fine). You've got 3-5 minutes to do all of this. I think the glycerin would take the longest of all (but I haven't tried it myself!). The spring rates are not altered that much. It is IMPORTANT to have the bushings not "twisted" at normal ride height if you want the bushings to have the longest life. |
| mgphoto |
Mar 11 2026, 05:53 PM
"If there is a mistake it will find me" ![]() ![]() ![]() Group: Members Posts: 1,469 Joined: 1-April 09 From: Los Angeles, CA Member No.: 10,225 Region Association: Southern California |
Astroglide.
| Cvrguy |
Mar 11 2026, 10:04 PM
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place. Not sure if this is applicable here, though. Given that the bushings need to be fixed in position, I am looking for a way to increase the "working time" between installation and when the soap dries out. Would glycerin take longer or slower to set up? I'm not confident that the measurements I took prior to removal will be correct once installed. If they are incorrect, I could end up with too high a "bushing" spring rate. I'm curious as to how the factory did it initially. original factory bushings are vulcanized.. or melted into place. not a technique that can be recreated at home. both the ID and OD are melted to the metal parts and create a twist in the rubber as the car changes up and down. The original rubber flexes to a point. aftermarket bushings usually spin on the shaft example roller bearings, or even zerks to lubricate the moving part for plastic bushings. and one that does not move freely will add resistance or add to the total spring rate. Thanks. That's the best explanation I have heard to date. It makes perfect sense for an assembly line installation. I spoke with a retired automotive engineer yesterday and he agrees that it won't change the overall spring rate that much, particularly if the bushing carriers are set somewhere close to the static ride height setting. Now I understand why many use the Elephant Racing bushings. Thanks to all. |
| mgp4591 |
Mar 14 2026, 03:16 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,927 Joined: 1-August 12 From: Salt Lake City Ut Member No.: 14,748 Region Association: Intermountain Region
I watched a local bicycle shop install rubber(ish) handlebar grips on a mountain bike. They used hair spray. This provided lubrication while sliding the grips over the bar. Soon afterward the 'slipperiness' disappeared and the grip stayed put. So, I tried this method on my bike. Years later it still is securely in place. Not sure if this is applicable here, though. Given that the bushings need to be fixed in position, I am looking for a way to increase the "working time" between installation and when the soap dries out. Would glycerin take longer or slower to set up? I'm not confident that the measurements I took prior to removal will be correct once installed. If they are incorrect, I could end up with too high a "bushing" spring rate. I'm curious as to how the factory did it initially. original factory bushings are vulcanized.. or melted into place. not a technique that can be recreated at home. both the ID and OD are melted to the metal parts and create a twist in the rubber as the car changes up and down. The original rubber flexes to a point. aftermarket bushings usually spin on the shaft example roller bearings, or even zerks to lubricate the moving part for plastic bushings. and one that does not move freely will add resistance or add to the total spring rate. Thanks. That's the best explanation I have heard to date. It makes perfect sense for an assembly line installation. I spoke with a retired automotive engineer yesterday and he agrees that it won't change the overall spring rate that much, particularly if the bushing carriers are set somewhere close to the static ride height setting. Now I understand why many use the Elephant Racing bushings. Thanks to all. The Elephant bushings are really good...I'd stay away from Delrin or nylon. My pick would be the urethane with liberal silicone grease like you'd get from the pool supply store. Fit a zerk into a spot where you can access it easily with the suspension loaded and you're set. |
| GregAmy |
Mar 14 2026, 06:04 AM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,659 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
Any time I need a lube to do this kind of work, it's always a "personal lubricant" from the local CVS.
Yes, that. It's water-based so won't attack rubbers (pun intended) and it will eventually evaporate. |
| Front yard mechanic |
Mar 14 2026, 06:50 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,444 Joined: 23-July 15 From: New Mexico Member No.: 18,984 Region Association: None
Monkey butt works well
Mar 14 2026, 10:44 AM
| worn |
Mar 14 2026, 06:07 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,573 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| Superhawk996 |
Mar 14 2026, 11:20 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,831 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
Detergent won’t actually evaporate, nor glycerin. Glycerin is used all the time within the automotive industry to assemble press fit rubber bushings. It is used by the OEMs as well as the supply base. The bulk of the of glycerin is squeezed out by the press fit, the remaining thin film between the press fit parts is absorbed by the rubber (usually ~24 hours) you will find the bushing grips very tightly and will not rotate. Glycerin without exposure to water becomes tacky & sticky. External squeeze out will be washed away by water. Glycerin is a good assembly lube for rubber bushings. If you are queasy about the wife or your buddy’s finding Astroglide or KY-Jelly in your shop, here’s a commercial non-glycerin product specifically intended for bushing and rubber hoses. ![]() https://ipcol.com/wp-content/uploads/WhichP80_ePaper1710.pdf |
| Cvrguy |
May 4 2026, 03:00 PM
When I finally did the installation, it turned out to be much easier than anticipated. I boiled the crap out of them and used liquid Dawn.
Lo-Fi Version | Time is now: 4th May 2026 - 10:26 PM |
