| chandler1969 |
Apr 7 2026, 07:03 AM
Member ![]() ![]() Group: Members Posts: 121 Joined: 2-January 06 From: Georgetown, Ky Member No.: 5,352 Region Association: None |
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO.
| DennisV |
Apr 7 2026, 07:13 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 897 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. Went through this myself not long ago. You could try hitting them with a small propane or butane torch if you can control the flame. Otherwise I'd grab them with vice grips to break them free. Even if it's the threaded side for a secure grip. Replace the screws. Last resort cut them off with a Dremel. |
| Jamie |
Apr 7 2026, 07:24 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,202 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. ![]() ![]() Chandler1969 from Georgetown KY? Have we ever met, and we need to get in touch! |
| mepstein |
Apr 7 2026, 07:37 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,604 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
A bit of heat from an torch and then touch a piece of paraffin to the hot metal. Unlike oils that evaporate, paraffin will wick into the threads when hot. Works well most of the time.
| chandler1969 |
Apr 7 2026, 07:56 AM
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. ![]() ![]() Chandler1969 from Georgetown KY? Have we ever met, and we need to get in touch! Not sure if we have, although I'm in Lawrenceburg now but I do go to Georgetown from time to time. |
| chandler1969 |
Apr 7 2026, 07:57 AM
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. Went through this myself not long ago. You could try hitting them with a small propane or butane torch if you can control the flame. Otherwise I'd grab them with vice grips to break them free. Even if it's the threaded side for a secure grip. Replace the screws. Last resort cut them off with a Dremel. Thanks, I was thinking the same but wanted some expert advise before proceeding! |
| chandler1969 |
| 914werke |
Apr 7 2026, 08:43 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,614 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
Here you go!
http://www.914world.com/bbs2/index.php?s=&showtopic=360108&view=findpost&p=3007648 |
| 914werke |
Apr 7 2026, 08:44 AM
Whoops link didnt work ...Here you go!
HERE Ive found the best way is to use a small set of vise grip to bite the sides. The screws are junk anyway so go to town , all you have to do is loosen them |
| chandler1969 |
Apr 7 2026, 09:06 AM
| chandler1969 |
Apr 7 2026, 09:08 AM
| 914werke |
Apr 7 2026, 09:14 AM
Need some advise on rusted screws that hold the headlights in. They will not come out with a screw driver. I'm afraid I will strip or break the head. I have doused them with PB Blaster. Whats the best way to remove these? Obviously one is complete toast from PO. ![]() ![]() Nah Im just remiss on maintaining the store inventories. I have them. Ill update. (IMG:style_emoticons/default/headbang.gif) |
Lo-Fi Version | Time is now: 7th April 2026 - 08:27 PM |
