| rbmorrisiii |
Apr 9 2026, 08:59 AM
Newbie ![]() Group: Members Posts: 12 Joined: 21-July 08 From: OAKLAND, CA Member No.: 9,333 Region Association: Pacific Northwest |
I want to do a 5 lug conversion, and went and talked to Bill at Eason Auto Works in Oakland. He said he could do it, and the best way to go about it was sourcing front struts from a 74-81 911sc - complete with brakes. He also said it was going to be tough to find.
I've looked a little online, and it seems a little bleak, but also I'm not exactly sure what I'm looking for. Is there a photo or list or something that shows me absolutely everything I will need? Minimally? Maximally? Also, what's the best way to go about finding these things? What would you do? Any info would be much appreciated. |
| mepstein |
Apr 9 2026, 09:06 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,610 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Read this thread first - www.914world.com/bbs2/index.php?showtopic=105728
| 914werke |
Apr 9 2026, 09:08 AM
"I got blisters on me fingers" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,618 Joined: 22-March 03 From: USofA Member No.: 453 Region Association: Pacific Northwest
PM me I may have everything you re looking for
| 914Wes |
Apr 9 2026, 09:09 AM
Member ![]() ![]() Group: Members Posts: 53 Joined: 9-March 22 From: SO CAL Member No.: 26,388 Region Association: Southern California |
First step, determine which front struts you really want. This is based off what brakes you are going to run. You have options of 3.0" or 3.5" caliper spacing as well as Boge(black), Koni(red/orange), or Bilstein (green) front struts. Bilstein struts are the best if you are going to drop spindle (lower) the front end. Bilstein struts can only use Bilstein inserts. Boge struts are the best in terms of price and insert options since you can get Boge, Koni, or Bilstein inserts for them. Koni struts are more rare as they were special order options, can only take koni inserts, but are adjustable. If you go with 3.5" spacing you can do with A or S calipers. A perfect match for those in the rear would be Eric Sheas repop 914-6 calipers. If you do not want to upgrade your calipers you can use a 3.0" strut with solid rotor front rotor, or ad spacers and get a vented in the front. You can also go the cheap route and drill the rotors for 5 lug and install studs but that only gets you the benefit of 5 lug wheels.
| sixnotfour |
Apr 9 2026, 09:22 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,196 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
First step, determine which front struts you really want. This is based off what brakes you are going to run. You have options of 3.0" or 3.5" caliper spacing as well as Boge(black), Koni(red/orange), or Bilstein (green) front struts. Bilstein struts are the best if you are going to drop spindle (lower) the front end. Bilstein struts can only use Bilstein inserts. Boge struts are the best in terms of price and insert options since you can get Boge, Koni, or Bilstein inserts for them. Koni struts are more rare as they were special order options, can only take koni inserts, but are adjustable. If you go with 3.5" spacing you can do with A or S calipers. A perfect match for those in the rear would be Eric Sheas repop 914-6 calipers. If you do not want to upgrade your calipers you can use a 3.0" strut with solid rotor front rotor, or ad spacers and get a vented in the front. You can also go the cheap route and drill the rotors for 5 lug and install studs but that only gets you the benefit of 5 lug wheels. yup REDRUM |
| Jack Standz |
Apr 9 2026, 10:04 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 752 Joined: 15-November 19 From: Happy Place (& surrounding area) Member No.: 23,644 Region Association: None
| brant |
Apr 9 2026, 12:12 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,176 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
3 inch struts and brakes are easier to find and completely adequate
What pmb recommends and cheaper than 3.5 You still get the vented brakes that came on the -6 |
| brant |
Apr 9 2026, 12:14 PM
You’ll likely need new rotors, brake rebuild kits, and ball joints you can source from pmb
Lo-Fi Version | Time is now: 9th April 2026 - 01:52 PM |
