| worn |
Apr 21 2026, 10:33 AM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,565 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
I know this is a bit strange, but I want to be able to easily switch out my MSD Digital 6A with a spare 6AL box. The digital unit has a nice plug that makes it easy to disconnect it from the harness for replacement. I have an old non-digital box with the same wires, but it cannot be plugged into a socket - you have to connect each wire one by one. The fantasy is to wire the old box to the kind of connector found on a new box. That way if I have a failure I can make a quick switch and go along my way.
An even better solution would be to source the plug itself, but I haven't had any luck with that. p.s. it is for the 911, but I hope you will help anyway. |
Lo-Fi Version | Time is now: 21st April 2026 - 02:16 PM |
