| sixaddict |
Apr 22 2026, 04:19 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,060 Joined: 22-January 09 From: Panama City Beach, FL Member No.: 9,961 Region Association: South East States
Anyone have a photo of correct fuel line configuration between carburetors (and source).
Thanks |
| DennisV |
Apr 22 2026, 05:41 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 907 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Anyone have a photo of correct fuel line configuration between carburetors (and source). Thanks Did you peruse BaT? There are some very original cars with engine photos with carbs exposed on there. |
| fixer34 |
Apr 22 2026, 05:52 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,420 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Anyone have a photo of correct fuel line configuration between carburetors (and source). Thanks I'm charging the battery on mine right now, I can take a couple pictures. If you want concours originality though, be aware I pulled the cold start valve and fuel line T a long time ago. |
| 930cabman |
Apr 22 2026, 05:57 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,610 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
Anyone have a photo of correct fuel line configuration between carburetors (and source). Thanks I'm charging the battery on mine right now, I can take a couple pictures. If you want concours originality though, be aware I pulled the cold start valve and fuel line T a long time ago. Cold start valve? I was unaware our Weber equipped /6 engines had this feature |
| fixer34 |
Apr 22 2026, 06:16 PM
Anyone have a photo of correct fuel line configuration between carburetors (and source). Thanks I'm charging the battery on mine right now, I can take a couple pictures. If you want concours originality though, be aware I pulled the cold start valve and fuel line T a long time ago. Here you go. Fuel pump underneath, to the fuel filter and fuel rail to carbs. |
| fixer34 |
Apr 22 2026, 06:24 PM
Anyone have a photo of correct fuel line configuration between carburetors (and source). Thanks I'm charging the battery on mine right now, I can take a couple pictures. If you want concours originality though, be aware I pulled the cold start valve and fuel line T a long time ago. Cold start valve? I was unaware our Weber equipped /6 engines had this feature Yep, at least the very early models. 'T' into the fuel line after the filter, went to a valve that was temperature sensitive I believe and connected to the starter solenoid. That provided raw fuel to rails in the air cleaner housing that sprayed right down the carb stacks. What could possibly go wrong?? |
| 930cabman |
Apr 22 2026, 06:29 PM
Mr Fixer came through, great shots and
(IMG:style_emoticons/default/lol-2.gif) (IMG:style_emoticons/default/piratenanner.gif) "what could go wrong" LMAO Recalling, I have seen this before |
| sixaddict |
Apr 22 2026, 07:53 PM
Lo-Fi Version | Time is now: 22nd April 2026 - 09:07 PM |
