| TonyA |
Apr 25 2026, 03:13 PM
Nachmal ![]() ![]() ![]() Group: Members Posts: 685 Joined: 17-November 16 From: Hilltown PA Member No.: 20,596 Region Association: North East States
So the setting blocks that came with the butyl tape are as thin as the plastic clips for the trim. Doesn’t make sense. Windshield basically will sit on the clips. Of course I corrected this.
| IronHillRestorations |
Apr 25 2026, 07:42 PM
I. I. R. C. ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,928 Joined: 18-March 03 From: West TN Member No.: 439 Region Association: None
So the setting blocks that came with the butyl tape are as thin as the plastic clips for the trim. Doesn’t make sense. Windshield basically will sit on the clips. Of course I corrected this. On the clips isn't good, the blocks should center the windshield top to bottom. |
| TonyA |
Apr 25 2026, 08:36 PM
packages being sold as installation kits are wrong. One states setting blocks can be used for front windows and rear. I don’t think so!
Like i said if the setting blocks are as thick as the clips something is wrong. Am I the only one thats sees this. I would think that the setting blocks should be thicker than the plastic retainer clip for the molding. Cut in half and double up or put small pieces on top of the clips? |
Lo-Fi Version | Time is now: 25th April 2026 - 09:12 PM |
