| StarBear |
May 19 2026, 01:27 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,295 Joined: 2-September 09 From: NJ Member No.: 10,753 Region Association: North East States
Weird. Installing new B6 rear shocks with 914Rubber 100# springs but the bottom of spring doesn’t lock in the plate that came with the shock; it can slip to one side even when loaded onto shock. Pic of existing shock and bottom plate shows it’s maybe a press fitting?
What to do?? Friendly helpful advice appreciated! ![]() ![]() ![]() |
| 914Sixer |
May 19 2026, 01:54 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,483 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Bilstein Cup is upside down. ALSO measure from top to bottom of spring plate on OLD shock. Then move your Bilstein cup CLIP to approximate height. Check distance again.
| StarBear |
May 19 2026, 02:02 PM
| StarBear |
May 19 2026, 02:03 PM
Yep, inverting it works as the inner shelf acts to keep it centered and in place.
Still no clip; height looks ok. |
| Shivers |
May 19 2026, 03:19 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,402 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
| StarBear |
May 19 2026, 03:23 PM
Yep, inverting it works as the inner shelf acts to keep it centered and in place. Still no clip; height looks ok. When you turned the base over it came down on a clip in one of those groves. The clip is holding the base up Ahh, yes I noticed the lip. It's a clip. Still learning after 52 years of owning this thing... (IMG:style_emoticons/default/piratenanner.gif) |
| StarBear |
May 19 2026, 03:27 PM
BTW, anyone use the additional rubber spring (jounce bumper), P/N 901 343 301 00, Item #5 on diagram 402-00 with front bumper Bilstein B6 struts?
My old Boge struts have them; still in reasonable shape. |
Lo-Fi Version | Time is now: 19th May 2026 - 06:26 PM |
