| MrBMW2002 |
May 20 2026, 03:24 PM
Newbie ![]() Group: Members Posts: 5 Joined: 25-July 10 From: California Member No.: 11,976 Region Association: None |
| yello914 |
May 20 2026, 08:46 PM
Member ![]() ![]() Group: Members Posts: 67 Joined: 18-May 05 From: Southern California Member No.: 4,099 Region Association: None |
| MrBMW2002 |
May 26 2026, 05:30 PM
Reduced to 350 dollars shipped anywhere in the United States.
| MrBMW2002 |
Jun 11 2026, 11:19 AM
| MrBMW2002 |
Jun 23 2026, 11:07 AM
Reduced to 350 shipped anywhere in the United States.
| MrBMW2002 |
Jul 4 2026, 08:59 AM
Bump.
| bdstone914 |
Jul 24 2026, 07:51 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,354 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| MrBMW2002 |
Jul 24 2026, 04:46 PM
Bruce- Great questions. I think it fits the Chevy LS1, LS2, LS6, LS7, 4.8,
I hope this helps. Brad |
| Ninja |
Jul 24 2026, 07:08 PM
Member ![]() ![]() Group: Members Posts: 280 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
You might want to verify that...
Gen II (LS1 and up) are internally balanced. Early series 1 SBCs are too. (283/302/327/350) But the late series 1 (86 and up with 1 piece rear main seals) and the 400 are not. The late engines got roller lifters in 87 and un-drilled mechanical fuel pump mounts. That flywheel looks like it has been modified for an external balance engine in my book. I believe that will fit 86 and up series 1 SBC. If I was putting a series 1 SBC together, I would choose 87 and up 4 bolt main block and "Vortec" style heads. It is easy to build a 500+ hp engine with little more than stroker crank, medium cam, H-beams, valve springs, roller rockers using a basically stock block and heads. I might be wrong here but you're going to want to verify what you have before you sell it. Super nice-looking pieces for very low price! If I was planning an SBC 914 I'd have already purchased this from you! |
| bdstone914 |
Jul 24 2026, 09:13 PM
You might want to verify that... Gen II (LS1 and up) are internally balanced. Early series 1 SBCs are too. (283/302/327/350) But the late series 1 (86 and up with 1 piece rear main seals) and the 400 are not. The late engines got roller lifters in 87 and un-drilled mechanical fuel pump mounts. That flywheel looks like it has been modified for an external balance engine in my book. I believe that will fit 86 and up series 1 SBC. If I was putting a series 1 SBC together, I would choose 87 and up 4 bolt main block and "Vortec" style heads. It is easy to build a 500+ hp engine with little more than stroker crank, medium cam, H-beams, valve springs, roller rockers using a basically stock block and heads. I might be wrong here but you're going to want to verify what you have before you sell it. Super nice-looking pieces for very low price! If I was planning an SBC 914 I'd have already purchased this from you! (IMG:style_emoticons/default/agree.gif) |
| MrBMW2002 |
Jul 25 2026, 07:13 PM
| MrBMW2002 |
Aug 12 2026, 11:17 PM
Still available. Open to an offer.
Lo-Fi Version | Time is now: 20th August 2026 - 07:23 PM |
