| North Coast Jim |
May 22 2026, 08:14 AM
Member ![]() ![]() Group: Members Posts: 345 Joined: 11-December 15 From: Northern Ohio Member No.: 19,450 Region Association: MidAtlantic Region
I'm in need a rebuildable 2L case. Anything available out there ??
| bdstone914 |
May 22 2026, 09:45 AM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,307 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
| Ninja |
May 22 2026, 09:50 AM
Member ![]() ![]() Group: Members Posts: 214 Joined: 25-September 25 From: Granbury Texas Member No.: 29,004 Region Association: Southwest Region |
The cases are interchangeable.
Many folks prefer the earlier cases. All the original cases are now over 50 years old and all need at a minimum to be properly checked out by a machinist competent with air-cooled VW engines. This is rare now-a-days... It's even better if they know the differences between a T1 and a T4. |
| cgnj |
May 22 2026, 10:42 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 723 Joined: 6-March 03 From: Medford, NJ Member No.: 403 Region Association: None
I have three cases at the moment on FB ATM. W, What I believe is a replacement GA and EA code. All standard main and thrust. The saddles look good. here is the link
My facebook ad w code mtors have the biggest rib structure so least likely to need to be decked, but no windage tray. Best for more than 96mm bore. Wind I was young I always wanted a GA case. For most purposes EA is the way to go. |
Lo-Fi Version | Time is now: 22nd May 2026 - 10:52 AM |
