> Tangering shift rod/linkage set screw question
burlybryan
post May 25 2026, 10:12 AM
I have a buddy with a Rennshift shifter and Tangerine rod and linkage. He lost shifting while driving recently and from what I can tell, the rod separated from the splined linkage at the trans. I removed the set screw at the rear linkage and it not a cone screw.
Can someone confirm if these ever came with just basic set screws or were they always cone screws. I haven't pulled it apart to see if there is a remnant cone portion stuck in the shaft, but wanted to get an idea of what is supposed to be there. Chris' kit shows cone screws.
Thanks!
TRP
post May 25 2026, 11:01 AM
I am pretty confident that both set screws provided with my Tangerine kit are of the cone screw variety. I just reinstalled my linkage after a motor out rebuild and had both screws in my hand as I applied new loc-tite on them.
Jack Standz
post May 25 2026, 11:38 AM
Don't know if Chis made different versions over the years. However, the one we have came with two set screws on the splined shaft that goes into the shift console.
mlindner
post May 25 2026, 12:04 PM
And Chris side shift Alignment Tool is the best thing since sliced bread. It is so easy to use and the results are dead on. Had my 914 for 45 years and the shift pattern and gear engagement has never been this good. Best, Mark
ChrisFoley
post May 25 2026, 12:15 PM
I am Tangerine Racing
QUOTE(burlybryan @ May 25 2026, 11:12 AM) *
Thanks!
My older kits used a nice aftermarket steering U-joint at the rear which had splines like the factory steering parts. Those used two set screws at each end to keep them connected. There are also two cone screws in those kits. More recent kits eliminate the splined steering u-joint in favor of one identical to the front one, which are my own design and construction, adapted from something I used to buy (which got hella expensive). The newer kits use three cone screws but some of the adjustability of the old design is gone.
- Lo-Fi Version Time is now: 25th May 2026 - 01:07 PM
