| Speedo |
Jun 8 2026, 03:23 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 666 Joined: 7-November 06 From: Boulder Member No.: 7,170 Region Association: Rocky Mountains
I'm in the process of recovering my seats. The fiberglass passenger bucket has three holes on both sides of the base. Does it bolt directly to the floor? No brackets? I can't remember how it came out of the car. Seems weird to bolt it directly to the floor?
| gereed75 |
Jun 8 2026, 04:12 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,446 Joined: 19-March 13 From: Pittsburgh PA Member No.: 15,674 Region Association: North East States
dont have mine out in front of me but I seem to remember that it bolts down with nuts on studs that protrude from the floor pan
Im sure someone else will report with the definitive answer. |
| aturboman |
Jun 8 2026, 04:23 PM
Member ![]() ![]() Group: Members Posts: 170 Joined: 18-October 11 From: CA Member No.: 13,687 Region Association: None |
The fiberglass base is held to the floor by (4) small studs on the floor pan and 2 small bolts on the cross member. Here is a 6 with the attachment points circled.
I believe both are M6 fasteners as I recall. Attached thumbnail(s) |
| DennisV |
Jun 8 2026, 04:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,030 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
Does it bolt directly to the floor? No brackets? I can't remember how it came out of the car. Seems weird to bolt it directly to the floor? Yep. Directly to the floor. I just put mine back last weekend. @aturboman memory is correct. M6 nuts qty 4. M6 x15 bolts qty 2 (900 075 193 08). Plus washers. I think you will want to place your vinyl floor covering for the tunnel, door sills, and front seat rail before you install the backpad or seat bottom. |
| Speedo |
Jun 8 2026, 05:38 PM
Thanks everybody!
| rudedude |
Jun 9 2026, 07:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 575 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
I believe there is also a small 2 hole plate that helps hold it down on either side.
| DennisV |
Jun 9 2026, 01:32 PM
I believe there is also a small 2 hole plate that helps hold it down on either side. Can you share a photo and / or part number for that? Our car didn't have hold down plates, but it doesn't mean it wasn't removed and lost. Here was I took out of our 1970 914-6. ![]() |
| mepstein |
Jun 9 2026, 01:45 PM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,919 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
No hold down plates on the early seat base. Even though its fiberglass, there's no torque on the seat bottom from acceleration or braking. It's just sitting on the floor and held in position with the studs.
Flat washer, lock washer, nut. |
Lo-Fi Version | Time is now: 23rd September 2026 - 06:42 PM |
