| Shivers |
Jun 30 2026, 07:52 AM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,457 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
They are so minor, if I could get my hand in there. I'm looking
for a possible easy fix to smooth these out a bit. The bottom is beautiful, doesn't even need paint. ![]() ![]() |
| friethmiller |
Jun 30 2026, 08:20 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,346 Joined: 10-February 19 From: Austin, TX Member No.: 22,863 Region Association: Southwest Region
You'd need some PDR tools to push from inside the tank, I'd think.
| Shivers |
Jun 30 2026, 08:35 AM
| friethmiller |
Jun 30 2026, 09:18 AM
You'd need some PDR tools to push from inside the tank, I'd think. So drill a hole from the bottom to get the tool in. That is a good idea. Well, it may not be a good idea. (IMG:style_emoticons/default/confused24.gif) You could cut a small rectangle out of the bottom, fix the dent, and weld it closed. However, being that it is a vapor/gas overflow container... welding might not be the best idea. Others might be able to chime in. |
Lo-Fi Version | Time is now: 30th June 2026 - 11:03 AM |
