| Literati914 |
Jul 3 2026, 02:30 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,348 Joined: 16-November 06 From: Dallas, TX Member No.: 7,222 Region Association: Southwest Region |
My friend took his car to Ed Mayo of Mayo Performance to fix a no start after driving issue. Ed has been working on these cars since new and he knew exactly what the trouble was. He installed the item in the following picture and all is well now. He said they even used to have to do this to NEW 914s back in the day!
He explained it to my friend who only caught bits of the explanation. Something along the lines of the wire to the starter getting hot and needing a 1/2 volt extra from this add on, to overcome the issue. I assume it’s the typical heat related issue. BTW I think a lot of people assume vapor lock is the only heat related problem (fuel pump is in the front on this car). Can someone give a thorough explanation for what this is addressing and how? I’d love to see a wiring scheme of this fix also. Attached thumbnail(s) |
| Shivers |
Jul 3 2026, 02:56 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,465 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
The hot start kit. Mine uses a Bosch relay it bypasses the long skinny wiring running from your ignition switch to the starter. By using a dedicated, shorter wire directly from the battery, the relay, triggered by the ignition switch ensures the starter solenoid receives the full voltage it needs to engage the engine even when hot and suffering from electrical resistance.
@Literati914 |
| brant |
Jul 3 2026, 03:01 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 12,224 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains
Very common
I have the same Bosch The other more common similar solution is the ford relay which I’ve also used repeatedly |
| JamesM |
Jul 3 2026, 04:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,263 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I view these as more of a band-aid. Yes they are a solution but if you properly address the underlying problem its unnecessary.
I have had my hands on a LOT of 914s, never had to install a hot start relay, and in fact have removed quite a few of them. Underlying issue is usually voltage drop at the ignition switch contact, crappy starter solenoid, or both. I find the solenoids used on the modern gear reduction starters to be a lot less temperamental than the ones used on the factory/rebuilt starters. |
Lo-Fi Version | Time is now: 3rd July 2026 - 04:28 PM |
