| Rav914 |
Jul 26 2026, 05:14 PM
All-weather fan ![]() ![]() ![]() Group: Members Posts: 743 Joined: 15-April 07 From: WA Member No.: 7,669 Region Association: None |
I pulled my engine recently to do some cleaning/maintenance and saw the AAV was floating there with no real place to anchor it down. Is this where it's supposed to be located? It's a '74 1.8. I see I had run a grounding wire off of it to one of the engine tin screws. It's been many years since I rebuilt the motor and I completely forget how I did this. Thanks
Attached thumbnail(s) |
| fiacra |
Jul 26 2026, 06:47 PM
Person.Woman.Man.Camera.TV. = MCI ![]() ![]() ![]() Group: Members Posts: 740 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
1975 1.8. Mine is held down with the bracket you're using for the ground wire. I suspect you did that years ago because there was no place on your engine tin to hold it down and ground it (IMG:style_emoticons/default/confused24.gif) I can try to get better pictures later if you need them.
I'm overdue for the same task you are taking on. You don't realize how grungy your engine bay is until you take a picture to post to a public forum... The rest of the car looks nice (IMG:style_emoticons/default/smile.gif) ![]() |
| TRP |
Jul 26 2026, 07:22 PM
Member ![]() ![]() Group: Members Posts: 420 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
Ther AAV is secured by to screws to a bracket should that is bolted to the engine case via one bolt on the engine case between the air plenum and the oil filler tower. Super ironic that you post this today, I had to remove mine two days ago to investigate an air leak.
| Rav914 |
Jul 26 2026, 07:30 PM
Thanks gents! Appreciate the input. I'll dig through my box of extra parts, I bet the bracket is in there.
Lo-Fi Version | Time is now: 26th July 2026 - 08:28 PM |
