> Horn Ring Contacts, Grease or Not?
NARP74
post Aug 5 2026, 08:44 AM
While replacing my turn signal I noticed some old dried grease on both sides of the horn contacts. What should I replace it with? Does it need to be conductive?
DennisV
post Aug 5 2026, 10:05 AM
QUOTE(NARP74 @ Aug 5 2026, 07:44 AM) *
The factory manual says "Lightly grease contact ring for signal horn. Use electrical contact grease."
What they fail to clarify is, do they mean conductive or not. I have seen arguments both for and against conductive grease as well as dielectric grease. (IMG:style_emoticons/default/confused24.gif)
GregAmy
post Aug 5 2026, 10:48 AM
With a proper mechanical electrical contact, non-conductive dielectric grease is the proper use. Using conductive grease(?) will lead to spurious undesired connections.
If dielectric grease stops the electrical connection from functioning then you do not have a proper contact.
NARP74
post Aug 6 2026, 05:33 PM
Used some dielectric grease. I'll see how that works.
Shivers
post Aug 6 2026, 06:09 PM
I did some research when I decided to go with a stock wheel on Howard. It was mentioned at at the bird board and others, a thin film of lithium or a similar conductive lubricant. I chose this:
DennisV
post Aug 7 2026, 10:16 AM
I doubt this was around in 1970, but I found Wurth Stabilant 22A. German. Areas of use includes horn circuits. Not a grease though, which would seem to be a key requirement of the horn contact plate / contact pin application. Also $106!
FlacaProductions
post Aug 7 2026, 03:29 PM
@Shivers - did this eliminate the grinding noise that i get when turning the wheel and the lube of the day has worn off?
I'm looking for something long-lasting that keeps the rubbing/griding noise of the horn contacts at bay.
Shivers
post Aug 7 2026, 06:55 PM
QUOTE(FlacaProductions @ Aug 7 2026, 02:29 PM) *
I do not know yet, all my 72 stuff is going into Howard but I have to get Howard ready first. I'm shaking it Boss. I suspect it will. At least for a while. It may end up as part of my maintenance. The grease said it could handle extreme conditions, I figure if I replace the old fabric braided fuel lines I should be ok. From the internet:
"Hzutloer Copper Conductive Grease is physically and thermally "tough" under extreme conditions, as it is rated to withstand high temperatures up to 1,100 °C (2,012 °F). It uses copper powder to maintain conductivity while resisting rust, corrosion, and arcing on metal contact surfaces."
- Lo-Fi Version Time is now: 21st September 2026 - 05:51 AM
