| ctc911ctc |
Aug 6 2026, 11:01 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,378 Joined: 9-June 18 From: boston Member No.: 22,206 Region Association: North East States
70, 914-6 All stock, original carbs
All Teeners, In my last Buccee post i took the car for a drive and the carbs were not right though I did balance them using the Least Lean method. I will leave out that when I dropped the linkage to the carbs that the throttle cable got wrapped around the clutch assembly and what happened next (IMG:style_emoticons/default/mad.gif) I have been driving the car for the past few days and then I remembered Richard Towles voice telling me it is always dwell, start with the Dwell Grasshopper. So i went to set the dwell FORGETTING that the Ignition BOX makes dwell angle less relevant (time to charge,etc). BUT, i set it anyway! Dwell in a 914-6 is done with the Distro OUT of the car Where is the darn collar bolt located, grrr Is it an 8 or a 10......sigh its a 10, of course I went in with an 8 pull, Pull, PULL........10 minutes later.......pull, Pull, PULL and POP Dang, hitting my knuckles when the distro released was painful Distro on bench, reset (was a tiny bit tight) the gap Distro back into the car Where is that hole...........common question from me...... (IMG:style_emoticons/default/dry.gif) Put the distro back in PUSH, PUSH, ah in......pointing at the wrong angle Remove distro again - PULLING FOR 10 min.......dang got the other knuckle. Put the distro back in- angle is good, comutator pointing right at the fan housing...ahh RATS, did not set TDC prior to removing (IMG:style_emoticons/default/blink.gif) Removed the distro again. (IMG:style_emoticons/default/sad.gif) Set car in 5th Rock forward, never reverse ah, there it is TDC is white, 35deg is RED (one smart thing I did when Mark sold me the Flywheel - THANK MARK!) Get the distro into the hole - easier to find with practice (IMG:style_emoticons/default/dry.gif) get timing light ready start the car grind...grind...grind...nothing Check Electrics Is the power on the points - yes Does the ignition box create spark - pull plug rock the advance spring - SPARK Great Check a dozen things - LIGHT APPEARS OVER MY MARBLE HEAD 180degrees out of phase (IMG:style_emoticons/default/sad.gif) OK reset TDC, commutator pointing 180@ out of phase - THE REAL TDC has arrived PULLLLLLLLLLL out the distro (time 5 and counting) Rotate Put back in set the distro assembly pointed to the fan Start the car VrrrRoom! first try. If you are still here, I was trying to get rid of the bucking when this all began. Still bucks (IMG:style_emoticons/default/hissyfit.gif) QUESTION: I will retune the carbs (Stock everything on the carbs) but would you focus on other electric things - wires (new from Pelican), distro is rebuilt (there is a post about it) all new components on distro. OR For correct advance testing the 6000RPM advance must be at 35deg....if you adjust this are we not changing the idle advance too? Might the springs be wrong for the timing to be correct at 3000 RPM - bucking is at 2K, 3k and 4k when there is no load either positive or negative. THANKS in Advance! 35degrees! CTC |
| 930cabman |
Aug 6 2026, 05:16 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,833 Joined: 12-November 20 From: Buffalo Member No.: 24,877 Region Association: North East States
have you looked at AFR?
| ctc911ctc |
Aug 6 2026, 07:47 PM
| TRP |
Aug 7 2026, 10:32 AM
Member ![]() ![]() Group: Members Posts: 451 Joined: 2-September 23 From: Morgan Hill, CA Member No.: 27,559 Region Association: None
I think with the AFR, comment above, the thought imight be that if the car is too lean upon acceleration you get a lean pop surge herky jerky motion because the lean mixture burns slower than a properly tuned mixture, etc. etc.
I was dealing with a similar issue on my 4cyl EFI car and chased fuel mixture problems for a few weeks. Only to later discover it was a timing problem because of my A123 distributor was being crazy. (So... yes... totally the opposite situation/set up as you but possible still relevant?) I may be totally off base. Take it for what it's worth. If you went down the AFR investigation I would start slightly rich to rule out a too lean issue. The other option is your spark box. How is your voltage to the box? Does it have a low voltage issue that may be causing any disruption to the spark signal? I don't know your setup, just sharing other rabbit holes I went down. |
| 930cabman |
Aug 7 2026, 11:40 AM
yes, a bit rich is better than lean
| Superhawk996 |
Aug 7 2026, 12:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,070 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
yes, a bit rich is better than lean Running rich will not solve if the Venturis are too large. If Venturis are too large you lose air velocity when tipping in under light load cruise conditions. This loss of velocity is the root cause of temporary lean conditions until RPMs and air velocity pick back up. Running rich will help mask it but it will not solve a Venturi sizing issue. I keep reading that carbs are stock but after 50 years in the wild, stock carb bodies is not necessarily the same thing as stock Venturis. |
| mskala |
Aug 7 2026, 12:14 PM
R ![]() ![]() ![]() Group: Members Posts: 1,965 Joined: 2-January 03 From: Massachusetts Member No.: 79 Region Association: None
Hmm,
based on what I've seen from your engine and your posts about the distributor, seems like it could still be something bad on the distributor. If it was only just off the throttle stops, I would think side-to-side carb linkage adjustment, but that won't explain the higher RPM stuff. You could try something from my marelli stash if you want. |
| ctc911ctc |
Aug 7 2026, 07:22 PM
Thank Mark - i am going to recal the carbs tomorrow, will let you know!
| porschetub |
Aug 8 2026, 12:07 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,174 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Hmm, based on what I've seen from your engine and your posts about the distributor, seems like it could still be something bad on the distributor. If it was only just off the throttle stops, I would think side-to-side carb linkage adjustment, but that won't explain the higher RPM stuff. You could try something from my marelli stash if you want. (IMG:style_emoticons/default/agree.gif) certainly seems like electrical to me ,the OP should take up Marks offer of a replacement (tester ) dizzy, simple to change cap rotor and points for test ,one job off the list to check. Has the CDI been checked for correct operation ? it should be an early Bosch 3 pin unit and these are known to give issues due to their age ,my point is that you may have a partial miss-fire which could well be your "bucking issue" . Before proceeding further have you changed the plug leads as you said ? . Cheers. |
| ctc911ctc |
Aug 9 2026, 07:29 PM
Mark is awesome and has been a terrific source of wisdom. I will follow his lead. I had the ignition box out, it was dirty but seemed to work - the audio test works well (IMG:style_emoticons/default/wink.gif)
I am pursuing electrical - and will be re-tuning the carbs. Thank you, CTC Hmm, based on what I've seen from your engine and your posts about the distributor, seems like it could still be something bad on the distributor. If it was only just off the throttle stops, I would think side-to-side carb linkage adjustment, but that won't explain the higher RPM stuff. You could try something from my marelli stash if you want. (IMG:style_emoticons/default/agree.gif) certainly seems like electrical to me ,the OP should take up Marks offer of a replacement (tester ) dizzy, simple to change cap rotor and points for test ,one job off the list to check. Has the CDI been checked for correct operation ? it should be an early Bosch 3 pin unit and these are known to give issues due to their age ,my point is that you may have a partial miss-fire which could well be your "bucking issue" . Before proceeding further have you changed the plug leads as you said ? . Cheers. |
| porschetub |
Aug 10 2026, 12:10 AM
Just be aware the unit can "buzz" even when faulty ,get your dizzy sorted then move on to the CDI see how you go cheers.
| ctc911ctc |
Aug 27 2026, 06:11 PM
I just added to the carb thread the results in more detail from today.
http://www.914world.com/bbs2/index.php?sho...p;#entry3269842 One thing that is good about not working on the car for a while is you start from zero. I reset all of the carb dials Air, idle, water (water?!?) and found that two of the air screws were more than 3 turns out . Not good! The car started to idle perfectly, I will re-perform the least-lean process tomorrow. Once I got the carbs reset to a starting point I found that the airflow on 1,2,3 vs, 4,5,6 was 3.5 vs 7. YOW, something is not right Dropping the throttle links and starting over tomorrow - also will chase the vibration in the carbs i discovered today. See link above. THANK YOU TEENERS! |
Lo-Fi Version | Time is now: 21st September 2026 - 05:50 AM |
