| DennisV |
Aug 20 2026, 09:07 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,054 Joined: 8-August 20 From: Santa Rosa, CA Member No.: 24,575 Region Association: Northern California
What have you found or fabricated to tighten the 13 ATF hex nut on 914-6 heat exchanger passenger side? I think that's cylinder number 1.
I'm sure this is probably mechanics 101, but I'm having a hard time with it. I've tried every combination of 1/4 socket, u-joint, wobble extender, flex driver I can find. No room for a box or open end wrench as 2 sides are blocked by bracket and pipe. Nothing I've tried provides enough engagement to properly tighten it. ![]() |
| Cairo94507 |
Aug 20 2026, 09:13 AM
Michael ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,801 Joined: 1-November 08 From: Auburn, CA Member No.: 9,712 Region Association: Northern California
Hi Dennis, Yeah there is a special wrench that is bent kind of like a Z that allows you to get in there and tighten that nut with ease. Good luck, Michael (IMG:style_emoticons/default/beerchug.gif)
| rudedude |
Aug 20 2026, 09:23 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 576 Joined: 1-January 05 From: minneapolis, mn Member No.: 3,387 Region Association: Upper MidWest
SSI included either a 12mm or 13mm z shaped wrench with their replacement exchangers. Maybe ask around. I have used 12mm across the flats nuts and seems to make it easier.
| sixnotfour |
Aug 20 2026, 11:05 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,424 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
best kept secret,,
https://www.amazon.com/dp/B0BB8R2973?lv=shu...rect=mhFallback |
| Steve |
Aug 20 2026, 11:35 AM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 6,126 Joined: 14-June 03 From: Laguna Niguel, CA Member No.: 822 Region Association: Southern California
I use a stubby 13mm wrench. I did see S wrenches on Amazon. Never seen a Z wrench
| mepstein |
Aug 20 2026, 11:45 AM
914-6 GT in waiting ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 20,994 Joined: 19-September 09 From: Landenberg, PA/Wilmington, DE Member No.: 10,825 Region Association: MidAtlantic Region
Often called a distributor wrench
Attached thumbnail(s) |
| sixnotfour |
Aug 20 2026, 12:14 PM
The support strap needs the hole slotted so it can move away , If you insist on a 13mm hex.. and your studs short..
| Superhawk996 |
Aug 20 2026, 01:16 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,179 Joined: 25-August 18 From: Woods of N. Idaho Member No.: 22,428 Region Association: Galt's Gulch
and your studs short.. (IMG:style_emoticons/default/agree.gif) Thats going to fail. Crows foot is another option for tools |
| porschetub |
Aug 20 2026, 04:40 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,200 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Sadly yes (IMG:style_emoticons/default/agree.gif) ,not enough thread to support the hex nuts or the barrel nuts if all studs are the same ,well prior to fitting my exhaust I removed one bad one and ordered 12 new studs from Pelican , length was spot on . The only fix I can see is to restud the heads ..don't think there is any other solution . |
| fixer34 |
Aug 20 2026, 05:38 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,486 Joined: 16-September 14 From: Chicago area Member No.: 17,908 Region Association: Upper MidWest
Want to say I used a ratcheting box end, swivel head wrench.
I'll see if I can get a picture of it tomorrow. |
| mepstein |
Aug 20 2026, 06:23 PM
Yea, unless that’s some sort of optical illusion, you’re going to have to fix that.
| nivekdodge |
Aug 20 2026, 06:52 PM
Member ![]() ![]() Group: Members Posts: 341 Joined: 28-August 21 From: Pittsburgh Pa Member No.: 25,860 Region Association: MidAtlantic Region
even on a four kevin |
| DennisV |
Aug 21 2026, 07:33 AM
(IMG:style_emoticons/default/ohmy.gif) That is an interesting idea. Wasn't aware of these. Only the copper exhaust nuts which I think are 12 mm ATF and I was planning to transition to. and your studs short.. Thanks for pointing that out. I believe that's an optical illusion because I haven't tightened the nuts before taking that photo. At least I hope that's the case. I've learned a painful lesson during this project. Never trust the stud height on anything. I would have liked to think that a highly rated machine shop would have caught / corrected these things, since they would have had to remove and reinstall in many cases, but clearly not. It has bitten me a couple time now. Too short on the intake side and I had to replace them all. One of the barrel nuts on the exhaust side was too long and I could only torque it to 10 ft. lbs. before the wrench hit the stud. |
| DennisV |
Aug 21 2026, 07:42 AM
Often called a distributor wrench Thank you for the photo Mark. That helps clarify. I started looking for an SSI wrench based on @rudedude comment. That is a crazy looking wrench! |
| mepstein |
Aug 21 2026, 10:35 AM
Often called a distributor wrench Thank you for the photo Mark. That helps clarify. I started looking for an SSI wrench based on @rudedude comment. That is a crazy looking wrench! Yes, we also called them an Ssi wrench but distributor wrench will be an easier search. Definitely worth grabbing one for the tool box. They are pretty inexpensive. |
| bdstone914 |
Aug 22 2026, 09:50 PM
bdstone914 ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,424 Joined: 8-November 03 From: Riverside CA Member No.: 1,319 |
@DennisV
![]() [/quote] Are all the studs the same lenght? The one puctured is too short. Why is the piece of metal under the nut? Attached thumbnail(s) |
| DennisV |
Aug 23 2026, 08:07 AM
| mepstein |
Aug 23 2026, 08:47 AM
| Steve |
Aug 23 2026, 12:22 PM
Why is the piece of metal under the nut? I can't tell you its purpose. Only that it is a new heat exchanger and there is a little bracket there. It’s stock oem It helps prevent the exchanger from rattling. |
| sixnotfour |
Aug 23 2026, 02:43 PM
Dansks version of the bracket... is the odity.
Rusty OG in Pictures... Nuts... 13mm Hex. notice ample room around hex for a flex socket 1/4 drive. ![]() 12mm Hex. More room.. ![]() 10mm Hex flange,, non locking.. easy. Bug guys used to pay $3 a piece for these.. ![]() Countdown .. 13 12 10mm.. notice the same diameter contact area.. 10 & 13 slightly more than a plain 12 nut.. ![]() |
Lo-Fi Version | Time is now: 13th November 2026 - 12:20 PM |
