| jmargush |
Sep 16 2026, 02:31 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 512 Joined: 8-June 04 From: Goshen, IN Member No.: 2,176 |
I upgraded to RE71rz for autoxv this year.
I am super impressed with these other than I am wearing the outside edge with almost no wear on the inside. Tangerine camber boxes are installed camber maxed out and cater naxed or at around 4.75 degrees. Anyone else experiencing this or more importantly have a solution. Attached thumbnail(s) |
| jmargush |
Sep 16 2026, 02:32 PM
| stownsen914 |
Sep 17 2026, 01:04 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,032 Joined: 3-October 06 From: Ossining, NY Member No.: 6,985 Region Association: None |
How much camber were you able to get? Not familiar with those tires specifically, but R compound racing type tires often like 3 degrees or more negative camber. If you have less and are driving on track (probably same deal with autocross), they'll tend to wear on the outer edges.
| infraredcalvin |
Sep 18 2026, 12:51 AM
Distracted Member ![]() ![]() ![]() Group: Members Posts: 1,775 Joined: 25-August 08 From: Ladera Ranch, CA Member No.: 9,463 Region Association: Southern California
I would say air pressure, but it looks like your roll over is ok at the indicators….
| jmargush |
Sep 18 2026, 04:58 AM
I would say air pressure, but it looks like your roll over is ok at the indicators…. I wondered about pressure as well, but the outer roll over looks correct. I'll have to check to see what the camber number is. I'm also going to Sema so hopefully I can talk to someone at Bridgestone. If i need more camber are there any solutions like a different ball joint? Or would a-arms need to be modified? |
| sixnotfour |
Sep 18 2026, 08:51 AM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,378 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
| sixnotfour |
Sep 18 2026, 09:05 AM
front end pushing ?
| jmargush |
Sep 18 2026, 03:14 PM
Camber is -2 degrees
Car is not pushing |
| stownsen914 |
Sep 19 2026, 06:40 AM
2 degrees isn't too bad. The other possibility is too much toe in - that can cause wear like that at the outer edge.
Is it a dual use car? One of the challenges with a dual use car is figuring out whether uneven wear is from hard use like autocross/track vs. accelerated wear from street use. Especially with soft track tires, and also because autrocross/track alignment setups can increase tire wear for street driving. A couple other thoughts: How's your toe set? Toe in can cause increased wear at the outer edges of tires. To optimize your camber, one option is to take tire temps after autocross runs (or track sessions) and look for even temps. |
| infraredcalvin |
Sep 29 2026, 08:31 PM
Lo-Fi Version | Time is now: 4th October 2026 - 10:55 PM |
