| Krieger |
Oct 2 2026, 06:04 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 4,902 Joined: 24-May 04 From: Santa Rosa CA Member No.: 2,104 Region Association: None
What have you guys used that works well and lasts? I have a 2011 Chevy. I used the Cerakote kit. It lasted a little more than two years before it started to come off and yellowing came back in more areas than before. The car was garaged more than half the time too.
| bkrantz |
Oct 2 2026, 08:08 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,826 Joined: 3-August 19 From: SW Colorado Member No.: 23,343 Region Association: Rocky Mountains
I have yet to see one, used by me or friends, that lasts.
| dtmehall |
Oct 2 2026, 08:18 PM
Member ![]() ![]() Group: Members Posts: 403 Joined: 21-December 23 From: Michigan Member No.: 27,808 Region Association: Upper MidWest |
| Shivers |
Oct 2 2026, 08:31 PM
Senior Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,733 Joined: 19-October 20 From: La Quinta, CA Member No.: 24,781 Region Association: Southern California |
This is what I used about a year ago. They still look good.
Link below to the item on Amazon. Amazon |
| Krieger |
Oct 3 2026, 08:44 AM
Yup, the other two available are Sylvania or 3M. I guess pick one and see how long it lasts. Thanks for the input guys!
| fiacra |
Oct 4 2026, 03:49 PM
Person.Woman.Man.Camera.TV. ![]() ![]() ![]() Group: Members Posts: 770 Joined: 1-March 19 From: East Bay Region - California Member No.: 22,920 Region Association: Northern California
I've used the 3M headlight restoration kit two times now, and both times the results were only acceptable for about 18 months. This last time I purchased a 3" hook and loop backing pad for my Milwaukee drill and an assortment of sanding disks. Worked my way up through the grades of sandpaper, finished off with a hand polish, and then applied two coats of clear coat. Turned out looking great, but longevity has not yet been determined. At least the cost for everything was just over what I would have paid for one kit, and I have enough sandpaper and clear coat to do at least five sets of headlights, maybe more.
| anderssj |
Oct 4 2026, 07:09 PM
Dog is my copilot... ![]() ![]() ![]() Group: Members Posts: 1,809 Joined: 28-January 03 From: VA Member No.: 207 Region Association: MidAtlantic Region
I've used the 3M headlight restoration kit two times now, and both times the results were only acceptable for about 18 months. This last time I purchased a 3" hook and loop backing pad for my Milwaukee drill and an assortment of sanding disks. Worked my way up through the grades of sandpaper, finished off with a hand polish, and then applied two coats of clear coat. Turned out looking great, but longevity has not yet been determined. At least the cost for everything was just over what I would have paid for one kit, and I have enough sandpaper and clear coat to do at least five sets of headlights, maybe more. (IMG:style_emoticons/default/agree.gif) I did the same for my wife’s 99 Miata and neighbor’s 09 Santa Fe…except for the clear coat. Worked up from wet sanding with 400 up to about 3000 grit, then used Meguiar's PlastX cleaner for the hand polish followed by a Mother’s wax with UV protectant. It stays pretty clear for a few months, but I can clear them up again in about 15 minutes with just the PlastX and the wax. Hope this helps! |
| Krieger |
Oct 4 2026, 10:25 PM
I've used the 3M headlight restoration kit two times now, and both times the results were only acceptable for about 18 months. This last time I purchased a 3" hook and loop backing pad for my Milwaukee drill and an assortment of sanding disks. Worked my way up through the grades of sandpaper, finished off with a hand polish, and then applied two coats of clear coat. Turned out looking great, but longevity has not yet been determined. At least the cost for everything was just over what I would have paid for one kit, and I have enough sandpaper and clear coat to do at least five sets of headlights, maybe more. Interesting! What are you using for clear coat? |
| fiacra |
Oct 4 2026, 11:05 PM
Eastwood Diamond Clear Gloss. It's not cheap, but I had some on the shelf from another project. Meguiar's makes a headlight coating that you spray on yearly to maintain your headlights, but I suspect the Eastwood product will be longer lasting.
| Jamie |
Oct 5 2026, 08:57 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,237 Joined: 13-October 04 From: Georgetown,KY Member No.: 2,939 Region Association: South East States
Eastwood Diamond Clear Gloss. It's not cheap, but I had some on the shelf from another project. Meguiar's makes a headlight coating that you spray on yearly to maintain your headlights, but I suspect the Eastwood product will be longer lasting. As a woodturner I have used the assortment of sanding materials on several frosty headlights, and buffed with NuFinish polish that has held up well. May not be permanent, and I suspect some of the ceramic polishes available now might be even better, but I haven't used any so far. (IMG:style_emoticons/default/confused24.gif) |
| sixnotfour |
Oct 5 2026, 09:05 PM
914 Wizard ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 11,443 Joined: 12-September 04 Member No.: 2,744 Region Association: NineFourteenerVille
I just used the 3M ultra kit,, comes with drill powered polishing discs..
3M Ultra Headlight Restoration Kit 39195 very clear .. utah is hard on plastic.. |
Lo-Fi Version | Time is now: 24th November 2026 - 05:02 PM |
