| Flyinlow |
Oct 6 2026, 11:05 AM
Flyinlow ![]() ![]() Group: Members Posts: 181 Joined: 17-October 20 From: British Columbia, Canada Member No.: 24,774 Region Association: Canada
Hi.. installed a new voltage regulator a BWD (BORG WARNER) R588 on first start up generator light came on and stayed till I gave it a rev stock vdo volt gage climbed to 16 volts and looked like it wanted more. Is this a problem? What does the brain trust suggest? (IMG:style_emoticons/default/confused24.gif) TIA Dennis
| GregAmy |
Oct 6 2026, 12:11 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 2,722 Joined: 22-February 13 From: Middletown CT Member No.: 15,565 Region Association: North East States
| JamesM |
Oct 6 2026, 01:46 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,372 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I would put an actual multi-meter on it rather than trusting the dash gauge, but yeah, 16v to the battery is something your battery is not going to enjoy for extended periods of time. |
| Flyinlow |
Oct 6 2026, 02:06 PM
I don’t have a battery issue mine is a AGM only a few months old all I did was replace the aging VR.is there a test? As this has been installed the flaps won’t want it back |
| GregAmy |
Oct 6 2026, 02:39 PM
I don’t have a battery issue... That link is info to troubleshoot your charging system. EDIT: link corrected to the following: http://www.914world.com/bbs2/index.php?sho...26479&st=20 And if you determine that this FLAPS VR is bad, they should warranty it. |
| Artfrombama |
Nov 9 2026, 03:24 PM
Artfrombama ![]() ![]() Group: Members Posts: 496 Joined: 21-January 24 From: One of the chosen few Member No.: 27,870 Region Association: South East States
Bosch 0 192 062 007 solid state regulators are now available priced reasonably https://cars245.com/en/item/bosch-F026T0223...ator-regulator/
| porschetub |
Nov 9 2026, 05:15 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,204 Joined: 25-July 15 From: New Zealand Member No.: 18,995 Region Association: None |
Bosch 0 192 062 007 solid state regulators are now available priced reasonably https://cars245.com/en/item/bosch-F026T0223...ator-regulator/ Nice original looking upgrade unit ,could be solution if it fits the relay board and the cover fits nicely also ,cheers. |
| Flyinlow |
Nov 10 2026, 02:36 PM
Bosch 0 192 062 007 solid state regulators are now available priced reasonably https://cars245.com/en/item/bosch-F026T0223...ator-regulator/ Anyone have experience with this Bosch voltage regulator? F026T02230 Does it fit? (IMG:style_emoticons/default/dry.gif) |
| 914Sixer |
Nov 10 2026, 03:25 PM
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 9,613 Joined: 17-January 05 From: San Angelo Texas Member No.: 3,457 Region Association: Southwest Region
Yes Bosch unit is plug and play. 1/2 size and solid state.
| emerygt350 |
Nov 10 2026, 07:37 PM
Advanced Member ![]() ![]() ![]() ![]() Group: Members Posts: 3,835 Joined: 20-July 21 From: Upstate, NY Member No.: 25,740 Region Association: North East States |
Bosch 0 192 062 007 solid state regulators are now available priced reasonably https://cars245.com/en/item/bosch-F026T0223...ator-regulator/ Anyone have experience with this Bosch voltage regulator? F026T02230 Does it fit? (IMG:style_emoticons/default/dry.gif) I have one. Didn't like it as much as the 30 dollar Amazon solid state adjustable I have been using for years now. The adjustable bit is really as good as it sounds. https://www.amazon.com/dp/B014GN1YLK?ref=fed_share |
Lo-Fi Version | Time is now: 23rd November 2026 - 10:16 AM |
