| cabrioartie |
Oct 10 2026, 06:16 PM
Newbie ![]() Group: Members Posts: 36 Joined: 8-October 24 From: Las Vegas, NV Member No.: 28,400 Region Association: None
Performed SirAndy's headlight alignment today. Everything went as he described. It should be noted, I have rubber covers over the area where the arm and spindle reside.
Anyways all went extremely well. I just have one little alignment issue with one of the eyebrows. It's just a little to far from one side, which makes it to close to the other side. I believe a little bending of the eyebrow tabs will resolve this issue. But, before I break something, I figured I would ask here. How do you remove the eyebrow? Is it just something you pull out, they seem to be in rather firmly. And, incase anyone asks, they seem to be mounted with the proper rubber grommets. |
| Ace Le Count |
Oct 10 2026, 07:27 PM
Looking for 4712908713 ![]() ![]() Group: Members Posts: 239 Joined: 20-February 18 From: Golden Valley, AZ Member No.: 21,910 Region Association: None |
Performed SirAndy's headlight alignment today. Everything went as he described. It should be noted, I have rubber covers over the area where the arm and spindle reside. Anyways all went extremely well. I just have one little alignment issue with one of the eyebrows. It's just a little to far from one side, which makes it to close to the other side. I believe a little bending of the eyebrow tabs will resolve this issue. But, before I break something, I figured I would ask here. How do you remove the eyebrow? Is it just something you pull out, they seem to be in rather firmly. And, incase anyone asks, they seem to be mounted with the proper rubber grommets. Thats what I did with mine. My car didn't have headlights mounted when I bought it. (Race car) All I had to do was bend the tabs. in my case, even the brow itself was bent. So, after spending some time doing some careful straightening, they fit great! They pull right out. It is easier to get your fingers under it if you remove the headlight surround first, then with the headlights up, they should lift right out. |
| NARP74 |
Oct 11 2026, 10:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,574 Joined: 29-July 20 From: Colorado, USA, Earth Member No.: 24,549 Region Association: Rocky Mountains |
DAPO alert! Mine were bolted in, check first.
Maybe not the PO, but certainly the inexperienced shop that worked on it. |
| 914sgofast2 |
Oct 11 2026, 05:47 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 816 Joined: 10-May 13 From: El Dorado Hills, CA Member No.: 15,855 Region Association: None |
Porshe used the 4 rubber cones to mount the eyebrows as a safety feature so a closing headlight would not take off any fingers that got in the way. The rubber mounting cones allow the eyebrows to come loose and move out of place to save your fingers in case someone closes the headlights when your have your hand in the way. Bending the tabs on the eyebrows is the only way to adjust the gaps on them. If the 4 rubber cones are worn out, then bending the tabs is the only way to make the gaps even; even new mounting rubbers will require bending adjustments to the eyebrow's tabs.
| cabrioartie |
Oct 11 2026, 07:29 PM
From everything I can see, I have the original mounting grommets holding the eyebrows in the car.
I thought, there ere 6 grommets, 3 on each side?? As that's how many I ordered. I'm assuming the ones I have will not be reusable. Between their age and my yanking the eyebrows out I assume they will be destroyed. |
Lo-Fi Version | Time is now: 11th October 2026 - 09:56 PM |
