| rick 918-S |
Nov 15 2026, 08:05 PM
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,380 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region
I do not believe I have ever seen this topic come up. The factory 6 had a black product applied around the strut top. Anyone have something to share on the subject.
| worn |
Nov 15 2026, 08:46 PM
Winner of the Utah Twisted Joint Award ![]() ![]() ![]() ![]() Group: Members Posts: 3,663 Joined: 3-June 11 From: Madison, WI and North Bend WA Member No.: 13,152 Region Association: Upper MidWest
| JamesM |
Nov 15 2026, 09:29 PM
Caretaker of 914s - Master of Fuel Injection ![]() ![]() ![]() ![]() Group: Members Posts: 2,357 Joined: 6-April 06 From: Kearns, UT Member No.: 5,834 Region Association: Intermountain Region |
I do not believe I have ever seen this topic come up. The factory 6 had a black product applied around the strut top. Anyone have something to share on the subject. Same stuff they slapped all over the 911s to seal the trunk. I believe @eric_shea might know. Some sort of rubberized wurth gunk if I recall. On 911s it provided some level of sealing of the front trunk around the shock towers but on the 914s as they sit behind the front trunk rear bulkhead seal, in the fuel tank compartment anyways that function was not needed. I think best guess was that it was used to identify the 6 tubs on the assembly line, but never saw anything definitive one way or another. Could be they did it for the same reason they did it to 911s without realizing its fairly pointless on a 914 tub. ran into a very original -6 in California and made a point to grab some pictures of how it was applied. much thicker than black paint, its almost like rubberized undercoating that was brushed on. Its an odd cosmetic detail on the -6s. Cool from an originality standpoint, but as the factory applied it over the top of the strut mounting hardware if you ever need to do an alignment you have to scrape it off anyways. |
| JamesM |
Nov 15 2026, 09:39 PM
Lo-Fi Version | Time is now: 16th November 2026 - 12:48 AM |
