| McMark |
Oct 21 2005, 11:43 AM
914 Freak! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 20,180 Joined: 13-March 03 From: Grand Rapids, MI Member No.: 419 Region Association: None |
I have seat belt mounts that have stripped threads. I'm wonding if HeliCoil's are strong enough in case of an accident. Logic tells me, yes they would be fine if installed correctly, but my gut is a little more nervous than my head. Can anyone tip the scales one way or the other for me?
| ArtechnikA |
Oct 21 2005, 11:47 AM
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None |
i have been down this path too, since there are *no* seat belt mounts in the tub of a '71 911 Targa...
i think i'd prefer a TimeSert over a HeliCoil, possibly with a bit of tack weld on the head... |
| Aaron Cox |
Oct 21 2005, 11:49 AM
Professional Tinkerer ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,548 Joined: 1-February 03 From: Corona, CA Member No.: 219 Region Association: Southern California |
| jhadler |
Oct 21 2005, 12:46 PM
Long term tinkerer... ![]() ![]() ![]() Group: Members Posts: 1,879 Joined: 7-April 03 From: Lyons, CO Member No.: 529 |
Reminds me of an old Bell Hemlet add campaign...
"If you've got a $10 head, buy a $10 helmet". In my opinion, seat belt anchors are one of those things that you can ill afford to do half-assed. Get it welded up and do it right. Timeserts and helicoils are great for some things. And while I might trust my engine to one, where precision is the most important thing, I don't think I'd be as comfortable trusting my life to one, where -strength- is the most important thing. Just my $0.02... -Josh2 |
| ArtechnikA |
Oct 21 2005, 12:58 PM
strength is important, but it is not absolute. i haven't cut up a tunnel or a B pillar to verify, but my understanding is that the OEM part is not merely tapped into the sheet metal, but is itself a threaded insert welded into the local structure. so at best, you could weld the outermost part closed and retap that, but i don't think you're going to be able to fill the whole insert with good weld material. the seat belt anchor mostly takes up a load in shear, so that's the strength you're concerned about. as long as the anchor can take a load perpendicular to the shank axis, it'll do its job. |
| jhadler |
Oct 21 2005, 01:03 PM
Yes, it's a welded in insert. But look at the insert, it's a far cry heavier than a timesert. And shear is certainly the key. I dunno, I guess I'm just a stickler for things like that. I like the knowledge that my belts will do their best to keep from hitting hard things (dash board, windshied, etc.) with soft things (me).
-Josh2 |
| goose2 |
Oct 21 2005, 02:37 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 976 Joined: 30-March 05 From: Eugene, Oregon Member No.: 3,847 Region Association: Pacific Northwest |
drill them larger and re tap for a bigger bolt?
| dlo914 |
Oct 21 2005, 03:03 PM
Whatchu' lookin' at?!?! ![]() ![]() ![]() ![]() Group: Members Posts: 3,433 Joined: 6-September 04 From: San Gabriel, CA Member No.: 2,697 |
speaking of seat belts...has anyone tried installing a 3rd seat belt for the center "seat"?
| McMark |
Oct 21 2005, 06:33 PM
Early cars have the supports and threads in place already. Stopped in 73 I think. For those cars it's a bolt in and you're done.
| banksyinoz |
Oct 21 2005, 07:43 PM
finally getting back into it ![]() ![]() Group: Members Posts: 223 Joined: 17-June 05 From: queensland, aus Member No.: 4,293 Region Association: Australia and New Zealand |
this is probably the best option if u cant get to the other side of the panel in question (i havent had to look yet) if you can you could replace the nut (weld nut to 3inx1in 10mm thick plate if doubtful this seems to be a manufacturing standard) then away you go or just use a bigger bolt i know i certainly wouldnt use a helicoil |
| Trekkor |
Oct 21 2005, 08:41 PM
I do things... ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,809 Joined: 2-December 03 From: Napa, Ca Member No.: 1,413 Region Association: Northern California |
Mark, is this your car or a customer's car? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) KT |
| nebreitling |
Oct 21 2005, 09:17 PM
Member Emeritus ![]() ![]() ![]() ![]() Group: Members Posts: 3,314 Joined: 26-March 03 From: San Francisco Member No.: 478 |
boy, that's going to be a tough fix. even over-tapping might not be great unless you can ensure some good threads.
but i would not personally strap into a heli-coiled belt ancor, and i'd sure as hell not put a loved one in that seat. |
| McMark |
Oct 21 2005, 09:19 PM
I'll have to agree with Rich's point that it's a shear load issue. The threads aren't what are doing the life saving. The threads are just to keep the bolt from falling out. I think that for the amount of material that is there makes TimeSerts less appealing to me (you'd end up thinning the wall of the support structure). Welding is probably the best option as long as you are a certified and trained welder with years of experience. Welding sheet metal and body pieces is one thing, welding shut what will basically become 3/4 thick material is completely another. Having heard some opinions and had a chance to think about things, I think HeliCoil is probably what I'll go with.
| John |
Oct 22 2005, 12:13 AM
member? what's a member? ![]() ![]() ![]() ![]() Group: Members Posts: 3,393 Joined: 30-January 04 From: Evansville, IN (SIRPCA) Member No.: 1,615 Region Association: None |
As I recall, the seat belt bolts have an unusual (at least to me) thread. I once had to get a tap to chase the threads out on one of mine and I had some difficulty finding the right tap. If you can get helicoils in that size I would be surprised. I would think about replacing the seat belt anchor. I know it might be a big pain, but at least you would know that the new anchor was strong.
just my $0.02 |
| McMark |
Oct 22 2005, 12:25 AM
Yeah, it's 12 mm x 1.25. Most 12 mm bolts are 1.5 or 1.75. I can get the HeliCoils. I've already done the research. (IMG:style_emoticons/default/wink.gif)
[EDIT]M11x1.25 NOT M12. Whoops.. (IMG:style_emoticons/default/pinch.gif) |
| neo914-6 |
Oct 22 2005, 12:28 AM
neo life ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,086 Joined: 16-January 03 From: Willow Glen (San Jose) Member No.: 159 |
The band-aids aren't worth the liability. Did the bolt mount get cross-threaded or was it worked free by belt movement over time?
Weld a nut or thread insert to a small plate with a hole, drill out the hole in the chassis to fit the nut and weld the assembly... |
| McMark |
Oct 22 2005, 12:37 AM
It looks like the threads were torn out during disassembly. A thread inset in a factory boss seems like a much safer solution to me than a complicated construction. I prefer a single point of potential failure, rather than a whole mess of them.
| banksyinoz |
Oct 22 2005, 11:27 PM
nissan exhaust manifold stud size from memory? doesnt sound real big though i will go check (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
| John |
Oct 22 2005, 11:46 PM
If you feel comfortable doing it, go with the helicoils.
The load is in shear, so we are not talking pullout. The only problem I see with the helicoils is getting the tang to break off correctly to allow the bolt to fully seat without screwing the helicoil out the back side of the anchor point. In other words, go for it. |
| ArtechnikA |
Oct 23 2005, 06:19 AM
you have started the research; it will be complete when you discover that seat belt bolts are 7/16" 20 tpi. there are a few places where Amrican sizing is used; this is one of them. |
Lo-Fi Version | Time is now: 2nd April 2026 - 07:50 AM |
