SLITS |
"This Utah shit is HARSH!" ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 13,602 Joined: 22-February 04 From: SoCal Mountains ... Member No.: 1,696 Region Association: None ![]() ![]() |
Steve |
914 Guru ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 5,620 Joined: 14-June 03 From: Orange County, CA Member No.: 822 Region Association: Southern California ![]() ![]() |
Yep, they swapped the vins.
Its either a 75 or 76. Nobody in there right mind would swap the front and rear clips to get the bumper shock mountings from a 75 or 76. They also didn't make a 1.8 motor in 71. I would ask to see a picture of the chassis stamping in the trunk on the passenger side. I live in Laguna Niguel. I think I have seen that car around. |
GaroldShaffer |
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,624 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None ![]() ![]() ![]() |
Quote from auction
"Q: I see that your vin tag reeds 471xxxxxxxx, and that should meen its a 71but look at your car/75 front bumper and rear. that is a 2.0 motor that has...more Nov-30-05 A: yes you are correct this car is a true 1975 with a 1.8 motor the car was salvadge it was changed at some time. thanks Mike " (IMG:http://www.914world.com/bbs2/html/emoticons/ph34r.gif) |
Cap'n Krusty |
Cap'n Krusty ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 10,794 Joined: 24-June 04 From: Santa Maria, CA Member No.: 2,246 Region Association: Central California ![]() |
Run, run for your life! A California DMV VIN change will have a plate riveted on the left door post, and it will have an assigned number with NO relationship to Porsche numbers. The Cap'n
Lo-Fi Version | Time is now: 17th June 2024 - 01:14 PM |
