Aaron Cox |
Professional Lawn Dart ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California ![]() |
got a space saver...on a steelie....
want it on a fuch.... like this.... (IMG:http://forums.pelicanparts.com/uploads6/CD+sauvegarde+700109648584510978733041130189711.jpg) |
echocanyons |
Advanced Member ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,094 Joined: 24-December 02 From: Bay Area, CA Member No.: 7 Region Association: Central California ![]() ![]() ![]() |
Yup it can and has been.
Some shops wont do it but keep looking there are plenty who will. basically remove and install on the fuch (IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif) |
Aaron Cox |
this is what the guys on PP said...
thanks... now can i stretch it onto a 7"? or does it have to be a 6"? |
bd1308 |
Sir Post-a-lot ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,020 Joined: 24-January 05 From: Louisville,KY Member No.: 3,501 ![]() |
if the tire is 6 inches wide and you stretch it to 7, you'll have the sides wearing out REAL fast. The center will collapse inward and you'll need more air pressure than what you want in order to keep that center inflated....
its not a good idea. stick close to the size....no more than 6.5 inch wide rim for 6 inch tire. b |
Aaron Cox |
your in error my friend.... as long as the bead sits.... your ok. how does it wear out the sides??? so your like / \ instead of | | big deal.... its a spare anyway.... question is... CAN i seat the bead on a 7" rim? 205's are perfect on a 7.. 225's are perfect for an 8... a 165 is too small for a 7???? probably.... |
Lo-Fi Version | Time is now: 17th June 2024 - 09:36 AM |
