| BarberDave |
Sep 8 2003, 03:50 PM
Barberdave ![]() ![]() ![]() Group: Members Posts: 1,605 Joined: 12-January 03 From: Wauseon Ohio Member No.: 135 Region Association: Upper MidWest |
What numbers should I get when doing a compresion check on a 73 1.7 . Looking to establish the genaral condition of the engine. If it's good I keep it and throw away the progresive carb. and install F.I. IF it doesn't check out then a 2.0 with F.I. Dave (IMG:style_emoticons/default/smilie_flagge6.gif) |
| kdfoust |
Sep 8 2003, 03:55 PM
Senior Member ![]() ![]() ![]() Group: Members Posts: 694 Joined: 2-January 03 From: Riverside Member No.: 71 Region Association: Southern California |
My '72 1.7: 170, 170, 170, 170
Good luck, Kevin |
| Bleyseng |
Sep 8 2003, 06:00 PM
Aircooled Baby! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 13,037 Joined: 27-December 02 From: Seattle, Washington (for now) Member No.: 24 Region Association: Pacific Northwest |
US spec or Calif Spec engine?? Two different compression ratios?
| kdfoust |
Sep 8 2003, 06:29 PM
QUOTE(Bleyseng @ Sep 8 2003, 04:00 PM) US spec or Calif Spec engine?? Two different compression ratios? Weren't '72s all the same (I don't know... (IMG:style_emoticons/default/rolleyes.gif) )? CA for sure BTW. |
| tat2dphreak |
Sep 8 2003, 07:03 PM
stoya, stoya, stoya ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 8,797 Joined: 6-June 03 From: Wylie, TX Member No.: 792 Region Association: Southwest Region |
I don't think they are ALL the same... not all had domed pistons...
| BarberDave |
Sep 8 2003, 07:10 PM
I don't know if it's U.S or Calif. spec. , if Calif. spec. had a smog pump then mine doesn't . Is there any way I can tell from the engine numbers? And it was brought new in Texas. Dave (IMG:style_emoticons/default/smilie_flagge6.gif) It now has a carb but ut orginaly had F.I. it has the wireing and a charcoal canister if that helps. |
| Bleyseng |
He asked " what should the compression be on a 73 1.7L?"
They come in two flavors low and high! or 8.2 to 1 or 7.6 to 1 ratios. Geoff |
| kdfoust |
Sep 8 2003, 07:52 PM
He asked about a compression check not compression ratio. Damn, I was hoping to get away with a half-assed answer.
Lo-Fi Version | Time is now: 9th June 2026 - 02:09 AM |
