fixed vs tilt passenger seat, front int crossmember |
rhodyguy |
Mar 15 2006, 12:57 PM
Chimp Sanctuary NW. Check it out. Group: Members Posts: 22,082 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch |
is the crossmember the same for all years just - the bracket for the cogged piece for the pass side tilt adj is not attached?
k |
turbo914v8 |
Mar 15 2006, 02:39 PM
Member Group: Members Posts: 373 Joined: 26-July 03 From: Canada Member No.: 952 |
For those models that have a back pad the passenger seat is not equipped with the tilt option.
Ask me how I know (IMG:http://www.914world.com/bbs2/html/emoticons/headbang.gif) The problem is that the rear tilting seat hinge is not present instead the rear of the seat is mounted solid, firm with two bolts to the floor. |
dimitri |
Mar 15 2006, 03:03 PM
dimitri Group: Members Posts: 101 Joined: 16-March 05 From: Cupertino,CA Member No.: 3,769 |
The crossmember is the same. If you add the hinges and the rack, change
backpad, you will have the platform for an adjustable seat. Dimtri |
Lo-Fi Version | Time is now: 23rd May 2024 - 05:18 PM |
