> PVC Intake?, diameter
yarin
post Mar 22 2006, 12:31 PM
'14-X'in FOOL
I bought most of the parts from home deport for a custom intake. I got a a rubber adapter from the throttle body to 2" ID to a 90 deg to 2" ID straight pipe.
Do I try to find a filter with a 2" ID or step up the PVC right after the 90deg bend to 2.5 or 3" then go with a larger filter. Is the 2" straight pipe to the filter too restrictive? Will this step down from 3 -> 2 -> 50mm -> 45mm increase my air velocity or am i dreaming? The PVC bends and adapter are actually not too detrimental to air flow, i smoothed out whatever hard lips on the inside.
Thanks
alpha434
post Mar 22 2006, 12:36 PM
My member number is no coincidence.
The 2 in pipe would be enough to feed your engine. It's the 90deg angle that will slow down your velocity the most. Airflow likes organic shapes. A 90deg angle in a tube isn't one of them.
(IMG:http://www.914world.com/bbs2/html/emoticons/wink.gif)
yarin
post Mar 22 2006, 01:00 PM
'14-X'in FOOL
Yea I know, don't have a choice there....
So 2" PVC has an OD of 2.375" = 60.32mm.
Do I go for a K&N with a 57mm ID flange or 62mm ID flange? I'm looking at one of these guys: http://www.knfilters.com/search/univ2.aspx?ID=S0014 About $25.
alpha434
post Mar 22 2006, 01:05 PM
I dunno. Your going to have to get a rubber press-fit piece. And then go with the largest diameter thats smaller than both of your pipes. And get some alocohol to get 'em together.
Matt Meyer
post Mar 22 2006, 01:33 PM
Überlurker
I think you can just band clamp the 62mm flange to the outside of the 2 in (60.32mm OD).
- Lo-Fi Version Time is now: 31st July 2025 - 08:49 PM
