1.7L injectors on a 1911cc engine |
mcbain77 |
Mar 27 2006, 09:38 AM
Member Group: Members Posts: 155 Joined: 27-January 06 From: Houston, TX Member No.: 5,485 |
Has anyone successfully used the 1.7L injectors for this engine displacement or will a switch to 2.0L injectors be required? running stock DJet.
Mueller |
Mar 27 2006, 09:42 AM
which fuel injection?
if stock, just use your 1.7..you might need to tweak the fuel pressure a tad bit or the MPS 1.7 injectors can flow more fuel than you'll ever need...same for the 2.0 injectors, lots of reserve built in |
Mueller |
Mar 27 2006, 09:49 AM
D-Jet information overload (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif)
the above site will tell you more about the D-Jet than most normal people are willing to digest (IMG:http://www.914world.com/bbs2/html/emoticons/smile.gif) shows flow numbers and just for the fun of it, you can find a fuel injector calculator on-line and plug in the numbers, you'll be amazed at how much HP both the 1.7 and 2.0 injectors can feed.... |
mcbain77 |
Mar 27 2006, 10:13 AM
Thanks for the tips! I have used that site for part numbers and basic reference so it is good to see I am using the right resources in my research.
Lo-Fi Version | Time is now: 2nd June 2024 - 01:19 PM |
