| GaroldShaffer |
Mar 27 2006, 04:30 PM
You bought another 914? ![]() ![]() ![]() ![]() ![]() Group: Benefactors Posts: 7,648 Joined: 27-June 03 From: Portage, IN Member No.: 865 Region Association: None
The VW cup holder I ordered came in today. This cup holder was mentioned in another thread here recently. It fits in to the ashtray location on older VW. Well seems there is a bunch of different sizes depending on what type VW you have. I emailed them asking for dimenstion info on the part that slides into the ashtray mount but of course I haven't heard anything back. After asking for some VW ashyray measurements here and other VW club sites I ordered the late style type III cup holder. I knew it wasn't going to be wide enough but looked like it would fit inside the 914 ashtray shell.
I took an old ashtray I had here and removed the black front plate and metal flip up clip and holder. I then cut the front metal section and bent it down. Now the new cup holder fit inside the shell but was to thick to slide all the way back in the shell. I cut the end of the holder off (polyresin type board) and just used 4 wood screws to hold it to the ash tray shell. Works like a champ. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) Fuctions like the old ashtray did, the ashtray shell is held in place buy the spring clip on top. Went for a high speed test drive with quick turns, never moved at all. It doesn't block the vent controls, slides back out of the way like the old ashtray did. I'm happy. Photo with holder pushed all the way back to the dash. Attached image(s)
| GaroldShaffer |
Mar 27 2006, 04:31 PM
Pulled all the way out to locking point of ashtray shell.
Sorry fuzzy pciture Attached image(s)
| GaroldShaffer |
Mar 27 2006, 04:32 PM
Cheap mounting setup.
| GaroldShaffer |
Mar 27 2006, 04:33 PM
Last one, bottom side.
| Chris Pincetich |
Mar 27 2006, 06:13 PM
B-) ![]() ![]() ![]() ![]() Group: Members Posts: 2,082 Joined: 3-October 05 From: Point Reyes Station, CA Member No.: 4,907 Region Association: Northern California |
Cool! Too bad it doesn't just slide in. Let us know if you get any more info - like the Type II fits better or whatever. It looks like the cupholder will work fine either pushed in or extended. (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) |
| seanery |
Feb 20 2007, 10:36 PM
waiting to rebuild whitey! ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Retired Admin Posts: 15,857 Joined: 7-January 03 From: Indy Member No.: 100 Region Association: None |
I can't believe I missed this one....great idea Garold (IMG:style_emoticons/default/thumb3d.gif)
| PinetreePorsche |
Feb 21 2007, 06:14 AM
Member ![]() ![]() Group: Members Posts: 235 Joined: 14-November 05 From: Falls Church, VA Member No.: 5,124 |
I bought a "spare" ash tray months ago, intending to kep one stock, modify the other by putting a piece of good wood in and cutting out a hole, maybe with a wire u-thing swinging loose under to bottom the cup, like the one in my '90 Subie. Like lots of things, I haven't gotten the round tuit i need to complete the job yet, so it remains in the planning stage. Has anyone done it, and can they post pics?
| seanery |
Feb 21 2007, 06:54 AM
search SMOG cupholder or smog cup holder... Curvie and the SMOG guys have a slick solution using an ashtray, a floppy disk, and 1 other item for the holder part.
| PinetreePorsche |
Feb 21 2007, 07:24 AM
search SMOG cupholder or smog cup holder... Curvie and the SMOG guys have a slick solution using an ashtray, a floppy disk, and 1 other item for the holder part. Seanery: I did the search, only got your post, quoted here--nothing else. What was the post about (old ash tray, or what?), how long ago--do you recall anything more? |
| seanery |
Feb 21 2007, 07:41 AM
Sorry for the hijack garold.
Here's a pic of the SMOG drink holder (IMG:http://www.914world.com/bbs2/uploads/post-2-1060617018.jpg) Here's a thread about it: Curvie's drink holder |
| Coy |
Jul 9 2007, 11:10 AM
Member ![]() ![]() Group: Members Posts: 352 Joined: 6-February 06 From: Salem, OR Member No.: 5,537 |
Update on the Volswagen drink holders:
I ordered the one for the VW Thing; it looks like this when istalled. ![]() The Thing cup holder has an angled joint that makes it level when pushed all the way back in as far as it will go. ![]() I took the bottom plug out and unscrewed the rings and screwed them down as low as I could. That put cup holders down out of my line of sight, but it covers up the heater controls. ![]() Take out all the extra stuff from the ashtray leaving just the shell. I cut off about 1 inch of the block and screwed two sheet metal screws through the bottom. ![]() I generally keep this cupholder behind my seat. I just pull it out and replace the 1 cup holder I made from the original ashtray whenever I have a passanger. That one looks like an ashtray when not in use. I'll post pictures of that one later; it looks just like the SMOG cupholder above, but without a floppy disk. |
| GaroldShaffer |
Jul 9 2007, 12:05 PM
Nice job. Wish I would have known about the VW Thing holder, but mine still works. I have plans to lower the holder also, but haven't done it yet.
| Coy |
Jul 9 2007, 12:34 PM
Actually, I bought the square back first. My 1991 Chevy pick-up didn't have a drink holder either, so I figured I could use the squareback there too. I took a chance and tried the Thing to see if it would work, and was pleased to see it was a little easier modification. It bounces quite a bit, but works pretty well. Thanks for the great idea to start with!
| geniusanthony |
Jul 31 2007, 05:15 AM
Its a brand new "Chrome-sicle" ![]() ![]() ![]() Group: Members Posts: 517 Joined: 12-December 05 From: Alexandria,VA Member No.: 5,266 Region Association: MidAtlantic Region |
For those of you with center consoles that are either non original or willing to cut(eek) another option is to find just about any almost luxo model and with a simple bracket, you can have a cupholder that retracts into the console when you press it in. when not retracted you have a real cupholder for two. the model I got mine from(sry no pics) was from a mid to late 90 Intregra GSR.
Oh BTW the last car I had this on was a late model CRX, havent tried it yet on the teener. |
| partwerks |
Apr 7 2011, 07:30 AM
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,621 Joined: 7-September 06 From: Grand Island, NE Member No.: 6,787 |
That's the one I had seen that a person could buy.
I intentionally kept mine with a low profile after it bottoms out as not to block my forward vision. I made the bends so that it was sitting level when pushed in. Don't have to worry about heater controls with water cooled, unless I would want to run the fresh air blower. I could have kept the distance between the bends closer, but I'm not building church pews. This way if I don't want to use it anymore, I can just remove the rivets and take it off with out having trashed the tray. |
Lo-Fi Version | Time is now: 9th June 2026 - 11:54 AM |
