pete-stevers |
saved from fire! ![]() ![]() ![]() ![]() Group: Members Posts: 2,648 Joined: 10-October 04 From: Abbotsford,BC, Canada Member No.: 2,914 Region Association: Pacific Northwest ![]() ![]() |
need to know what type of oil to by for the six....aprox how many litres
Eric_Shea |
PMB Performance ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 19,304 Joined: 3-September 03 From: Salt Lake City, UT Member No.: 1,110 Region Association: Rocky Mountains ![]() ![]() |
Which 6? 3.0?
ArtechnikA |
rich herzog ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,390 Joined: 4-April 03 From: Salted Roads, PA Member No.: 513 Region Association: None ![]() |
~9 liters says the spec book and owners manual.
assuming stock oil tank, no external cooler, etc... assuming 3,0 or less - but if it were bigger, you'd probably have an external cooler... 20-50 is fine, especially for dino oil and a summer car. i like 15W-50 synthetic. but the engine is pretty flexible in this regard. too much oil is bad - it'll just puke out the tank breather and make a mess, or get sucked into the intake and make a mess -and- an oil cloud ... |
pete-stevers |
it is a 3.0 six with a 914-6 tank, and a remote oil cooler up front
Eric_Shea |
The weight should be fine.
I've heard another 4 qts for the cooler and lines. CHECK THOUGH. |
J P Stein |
Irrelevant old fart ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,797 Joined: 30-December 02 From: Vancouver, WA Member No.: 45 Region Association: None ![]() |
I get 10 qts out at an oil change. I initially put in 12 qts.
I use 10-40 plankton. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
Allan |
Teenerless Weenie ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 8,373 Joined: 5-July 04 From: Western Mesopotamia Member No.: 2,304 Region Association: Southern California ![]() |
Mine runs on 20-50 and seems to do well. It's a 2.7 with no external oil cooler and runs around 180 to 200 oil temp.
The hottest it ever got was 210 over the grapevine and then cooled right back to 180 after I crested the top. |
Lo-Fi Version | Time is now: 31st July 2025 - 03:05 PM |
