pib |
Re Member ![]() ![]() Group: Members Posts: 116 Joined: 5-February 06 From: Monterey, CA Member No.: 5,530 ![]() |
So after a few helpful (IMG:http://www.914world.com/bbs2/html/emoticons/alfred.gif) from members this past week, I've started dealing with the rust on my '75.
I'm sure, as some have said, that this will turn into a complete resto (read: obsession), but I'm starting with the small stuff, and hoping to take what I learn from that into the bigger parts of the project. I took a bunch of 'before' pictures, which I'll try to post at some point, maybe a blog... First up, the trunks. Pictures are easier than a full description, so here you go: The red sled... Attached image(s) ![]() |
pib |
The back trunk...before
pib |
and after a first pass with the wire wheel on the grinder
porschecb |
Senior Member ![]() ![]() ![]() Group: Members Posts: 1,092 Joined: 13-August 04 From: Las Vegas NV Member No.: 2,529 Region Association: None ![]() |
Is that a hole I see in the floor?
pib |
That's really the worst spot, most of the rest was surface rust, and came off easily.
So now the questions... I got my little box of goodies from POR-15 last week, and I could use some advice. -How much do I need to brush/grind before using the Marine Clean? - How the heck do you rinse it clean with water...just hose it down and then mop it up? - Should I have the little hole welded up? Or can I just use the POR-15 filler product? -I haven't bought a welder, or used one since high school, that's a few weeks down the line I think. Does anyone have a good recommendation for a home MIG setup? Or advice on what to avoid? Thanks! -Pete |
pib |
Yup, a tiny little hole, and the only one in the trunk. The front trunk is much cleaner. The firewall is the worst of it...but I'll get there. |
jr91472 |
"I'm pacing myself sergeant..." ![]() ![]() ![]() Group: Members Posts: 1,205 Joined: 2-August 04 From: McKinney, TX Member No.: 2,437 ![]() |
You only need to brush the loose stuff off. A rough surface actually helps the POR-15 to bond (dis-regard that comment if you have CW intentions).
I think they say 1:1 water and marine clean. As yes, just mop out with a sponge or some such. A heat lamp does wonders to aid in drying. Repeat with the Metal Ready (but no dulution IIRC). If it were my car, I would just use a filler product for those tiny holes. But welding can be fun. enjoy the madness (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) |
dinomium |
Git on a chair son, all the good stuff is goin over yer head! ![]() ![]() ![]() ![]() Group: Benefactors Posts: 2,777 Joined: 2-January 03 From: Bremerton, WA Member No.: 74 Region Association: Pacific Northwest ![]() ![]() |
(IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png)
Nice way to start! I am now in the clean it up and DRIVE IT TILL NEXT WINTER camp! (IMG:http://www.914world.com/bbs2/html/emoticons/driving.gif) more fun than welding! Less burn marks, too! |
anthony |
2270 club ![]() ![]() ![]() ![]() Group: Benefactors Posts: 3,107 Joined: 1-February 03 From: SF Bay Area, CA Member No.: 218 ![]() ![]() |
You can use a wet/dry shop vac to vacuum the rinse water out. Take it for a half hour drive and it will be dry as a bone as the muffler is underneath the trunk. |
SirAndy |
Resident German ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Admin Posts: 42,244 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California ![]() |
actually, it won't as the moisture has nowhere to go/vent ... spray with metal-ready, let it dry, wipe off with wet spunge, let dry, paint with POR-15 ... if it was me, i'd be replacing that rusted sheetmetal. did you try poking with a screwdriver? i bet you can easily make that hole much bigger, the metal looks paper-thin there ... (IMG:http://www.914world.com/bbs2/html/emoticons/smash.gif) (IMG:http://www.914world.com/bbs2/html/emoticons/welder.gif) Andy |
Spoke |
Jerry ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 7,185 Joined: 29-October 04 From: Allentown, PA Member No.: 3,031 Region Association: None ![]() ![]() |
Yeah, I tried that too and ran out of screwdrivers. (IMG:http://www.914world.com/bbs2/html/emoticons/biggrin.gif) Spoke Attached image(s) ![]() |
pib |
Thanks guys!
I did try to poke some more, it's really pretty solid, it's just not really pretty. I think I'll grind a bit more on the really rough spot, and then get into mad-scientist mode with the POR products... The front trunk turned out to be nothing but a really light surface rust. (IMG:http://www.914world.com/bbs2/html/emoticons/smilie_pokal.gif) And then I pulled the seats and the backpad... (IMG:http://www.914world.com/bbs2/html/emoticons/barf.gif) The drivers side seat bracket mount was rusted through, and it looks like cracks under the passenger side as well. One other thing, I rad a few threads about having to scrape a bunch of tar and crap off under the carpets, mine appears to be just painted sheet metal. Was that a difference on early vs late models? (IMG:http://www.914world.com/bbs2/html/emoticons/confused24.gif) |
SirAndy |
if it's the original paint, there's tar underneath that paint ... the tar mats were glued onto the bare metal, then sprayed over. that's why you see so many rusted out floorpans. once the tar get's old and brittle, it cracks. water seeps in and works wonders on the bare metal underneath ... take a closer look .... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
pib |
Yeah, a closer look is on tomorrow's list of things to do, along with pulling the side trim off and looking/poking at the longs. We'll see just how bad it gets.
My son Kyle, hard at work here... So far, he's the best tool I've found for getting into those hard to reach places! Attached image(s) ![]() |
anthony |
Worked for me. You make it sound like 914 trunks are air tight or something. |
SirAndy |
dunno, mine leaks like hell, every time it rains or i go to the carwash i have about 1" of water in there. and if i leave it in there, it's still there a week later, no matter how much i drive the car. and it'll go from pooling at the lower part to a film of moisture everywhere in the trunk. so yes, i think most of the moisture will stay in the trunk, no matter how hot you get the trunk floor. and that can't be good ... (IMG:http://www.914world.com/bbs2/html/emoticons/cool_shades.gif) Andy |
rick 918-S |
Hey nice rack! -Celette ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 21,008 Joined: 30-December 02 From: Now in Superior WI Member No.: 43 Region Association: Northstar Region ![]() ![]() ![]() |
Looks like you have a good crew! (IMG:http://www.914world.com/bbs2/html/emoticons/welcome.png)
rhodyguy |
Chimp Sanctuary NW. Check it out. ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Group: Members Posts: 22,248 Joined: 2-March 03 From: Orion's Bell. The BELL! Member No.: 378 Region Association: Galt's Gulch ![]() |
there's stuff hiding under the seam seal in the trunk. sorry.
k |
anthony |
Please note that above I suggested that he vacuum out all of the water in the trunk with a shop vac. You only quoted half of my post. I didn't mean that he should drive around with an inch of water in his trunk and that it would evaporate. After vacuuming out any water a drive will definitely cause any residual dampness to evaporate away and then he could apply the Metal Ready or the Por15 depending on which step he is on. |
pib |
(IMG:http://www.914world.com/bbs2/html/emoticons/ohmy.gif) Yikes! So all of that whitish sealer needs to be ground out too? What do you use to replace the sealer after the metal is all cleaned & treated? And do you replace the sealer after the POR-15 and before final paint? Rick: He's a great helper. Loves to get his little hands dirty and turn those wrenches. Also great for fetching beer and pretzels! (IMG:http://www.914world.com/bbs2/html/emoticons/beerchug.gif) Now if I could just get him to do his homework... Thanks everyone for the tips! I think she's taken her last drive for a while, so it'll be shop-vac and heat lamp for me tomorrow. Maybe a trip to Home Depot to look at welders... |
Lo-Fi Version | Time is now: 4th July 2025 - 12:50 AM |
