225 50 15 tires on 7" cookie cutters, Will they fit well? Look ok? |
bondo |
Apr 17 2006, 04:17 PM
Practicing my perpendicular parking Group: Members Posts: 4,277 Joined: 19-April 03 From: Los Osos, CA Member No.: 587 Region Association: Central California |
I'm trying to plan ahead and design flares to match the final tire size. 225 seems to be the widest tire that is easily available in 15". Is this going to be wide enough for a V8 914 street car without limited slip? Is it too wide for a 7" wheel? Anyone running this particular size on a 7" rim? Got pics?
Just want to make sure I do it right the fist time. I looked into 8" cookies (welded), but they aren't cheap and tires to fit them would be expensive and hard to find. I really like the look of cookies, and I already have them, so I'm not going to switch to another wheel. (IMG:style_emoticons/default/smile.gif) |
bondo |
Apr 17 2006, 04:18 PM
Hmm, I selected "new topic", but the button at the bottom to submit the post said "add reply". But it did add it as a new topic. (IMG:style_emoticons/default/confused24.gif)
Aaron Cox |
Apr 17 2006, 04:23 PM
Professional Lawn Dart Group: Retired Admin Posts: 24,541 Joined: 1-February 03 From: OC Member No.: 219 Region Association: Southern California |
they work fine. 225's really look better on an 8" tho.
205 on 7 = perfect 225 on 8 = perfect |
spunone |
Apr 17 2006, 04:27 PM
Senior Member Group: Members Posts: 945 Joined: 6-April 04 From: Anaheim CA Member No.: 1,901 Region Association: Southern California |
Speaking of wheels (IMG:style_emoticons/default/screwy.gif) do they make a space saver fo a 4 lug fuch?
Aaron Cox |
Apr 17 2006, 04:28 PM
Speaking of wheels (IMG:style_emoticons/default/screwy.gif) do they make a space saver fo a 4 lug fuch? paul - you can put a space saver on any wheel.... i put one on a 6" 5 lug fuch. if the blogs get up again, ill show ya the pic of mine mounted. I had slits mount mine. lemme know if you are looking for a 15" saver.... |
brant |
Apr 17 2006, 04:34 PM
914 Wizard Group: Members Posts: 11,639 Joined: 30-December 02 From: Colorado Member No.: 47 Region Association: Rocky Mountains |
They should fit fine.
I've run 225 tires on 7 inch cookies for years. (I've seen wider tires on narrower rims in the past, but wouldn't recommend it. It was done to accomodate classification rules mostly and not because its the best combo... the best I've seen is a 245 tire on a 6inch rim...) but 7incher should work fine! brant |
SirAndy |
Apr 17 2006, 04:38 PM
Resident German Group: Admin Posts: 41,676 Joined: 21-January 03 From: Oakland, Kalifornia Member No.: 179 Region Association: Northern California |
Hmm, I selected "new topic", but the button at the bottom to submit the post said "add reply". But it did add it as a new topic. (IMG:style_emoticons/default/confused24.gif) yeah yeah, nag nag ... how about a "thank you andy for making the POST page much easier to work with" instead? (IMG:style_emoticons/default/biggrin.gif) as for your tires, i've been running 225/50x15 on cookie cutters for years now. works great. you'll need some spacers if you have GT flares ... (IMG:style_emoticons/default/smile.gif) Andy |
Mueller |
Apr 17 2006, 04:45 PM
what happened to the 16x9's??
did you see my reply to your post about fitting those rims?? I found a supplier for the outer shells to make them wider or smaller.... |
bondo |
Apr 17 2006, 05:16 PM
what happened to the 16x9's?? did you see my reply to your post about fitting those rims?? I found a supplier for the outer shells to make them wider or smaller.... Different 914.. the 16s are going on a 1.7 powered car.. all bark and no bite! (IMG:style_emoticons/default/smile.gif) I got them mounted now, and they fit fine. Had to use spacers to fill out the flares. The cookies are going on the V8 car, which will be 5 lug. No problem with flare filling, as they will be designed for the wheel/tire combo. What about use on a V8 914.. will 225s be wide enough, or is it going to be like driving around on ice? (IMG:style_emoticons/default/smile.gif) Andy: Thank you for making the POST page much easier to work with! (IMG:style_emoticons/default/biggrin.gif) |
DanT |
Apr 17 2006, 05:26 PM
Going back to the Dark Side! Group: Members Posts: 4,300 Joined: 4-October 04 From: Auburn, CA Member No.: 2,880 Region Association: None |
what happened to the 16x9's?? did you see my reply to your post about fitting those rims?? I found a supplier for the outer shells to make them wider or smaller.... Different 914.. the 16s are going on a 1.7 powered car.. all bark and no bite! (IMG:style_emoticons/default/smile.gif) I got them mounted now, and they fit fine. Had to use spacers to fill out the flares. The cookies are going on the V8 car, which will be 5 lug. No problem with flare filling, as they will be designed for the wheel/tire combo. What about use on a V8 914.. will 225s be wide enough, or is it going to be like driving around on ice? (IMG:style_emoticons/default/smile.gif) Andy: Thank you for making the POST page much easier to work with! (IMG:style_emoticons/default/biggrin.gif) Too little of tire for a v8 conversion. I had 225x50x15 Yoko A032Rs on the rear of my 914-6 2.7L RS motor and they still broke loose at will with the throttle. (IMG:style_emoticons/default/biggrin.gif) |
bondo |
Apr 17 2006, 06:23 PM
what happened to the 16x9's?? did you see my reply to your post about fitting those rims?? I found a supplier for the outer shells to make them wider or smaller.... Different 914.. the 16s are going on a 1.7 powered car.. all bark and no bite! (IMG:style_emoticons/default/smile.gif) I got them mounted now, and they fit fine. Had to use spacers to fill out the flares. The cookies are going on the V8 car, which will be 5 lug. No problem with flare filling, as they will be designed for the wheel/tire combo. What about use on a V8 914.. will 225s be wide enough, or is it going to be like driving around on ice? (IMG:style_emoticons/default/smile.gif) Andy: Thank you for making the POST page much easier to work with! (IMG:style_emoticons/default/biggrin.gif) Too little of tire for a v8 conversion. I had 225x50x15 Yoko A032Rs on the rear of my 914-6 2.7L RS motor and they still broke loose at will with the throttle. (IMG:style_emoticons/default/biggrin.gif) Great.. Well I want the tires to break loose before the teeth of the gears in the trans break loose, but I don't want it to be impossible to drive either. What width tire do you reccomend? And where do I find it in 15" diameter? (IMG:style_emoticons/default/smile.gif) I've been plugging numbers into tirerack and discount tire direct, but it's hard to be sure I'm getting all the possible combinations. What's available, and will it gain me enough width to justify widened cookie cutters? |
Aaron Cox |
Apr 17 2006, 07:36 PM
what happened to the 16x9's?? did you see my reply to your post about fitting those rims?? I found a supplier for the outer shells to make them wider or smaller.... Different 914.. the 16s are going on a 1.7 powered car.. all bark and no bite! (IMG:style_emoticons/default/smile.gif) I got them mounted now, and they fit fine. Had to use spacers to fill out the flares. The cookies are going on the V8 car, which will be 5 lug. No problem with flare filling, as they will be designed for the wheel/tire combo. What about use on a V8 914.. will 225s be wide enough, or is it going to be like driving around on ice? (IMG:style_emoticons/default/smile.gif) Andy: Thank you for making the POST page much easier to work with! (IMG:style_emoticons/default/biggrin.gif) Too little of tire for a v8 conversion. I had 225x50x15 Yoko A032Rs on the rear of my 914-6 2.7L RS motor and they still broke loose at will with the throttle. (IMG:style_emoticons/default/biggrin.gif) i agree with Danimal.... i can break my 225's on 8" fuchs loose with my hot 2.0 4. im interested to see your flare project! |
Leo Imperial |
Apr 18 2006, 06:15 AM
Do you have to use so many cuss words? Group: Members Posts: 906 Joined: 29-November 04 From: 914 Roadshow - Glen Cove NY Member No.: 3,192 Region Association: None |
205x55r15 on 6" front and 225x50r15 on 7" rear with yok es100's.
stock 2.0 and no slipo. Almost stock fenders (IMG:style_emoticons/default/biggrin.gif) Attached image(s) |
Lo-Fi Version | Time is now: 7th June 2024 - 07:48 PM |
